HEX broach too big for our manual press
So, we just received the HEX broach from andymark, and it doesn't fit into our manual 2 ton press.
The Broach is too long, and therefore we cant really use it. Are there any solutions anyone has for this kind of a problem? Will cutting the Broach somewhere in the middle, and therefore doing 2 presses every time we make a part work? thanks! |
Re: HEX broach too big for our manual press
Get a larger hydraulic press, trust me. Harbor Freight sells them or Amazon or wherever. It's worth the investment if you plan on broaching hex. |
This.
Cutting a broach is a good way to throw away $200. If the broach is only a little larger than the press, you might find that if you slot the broach into the hole of the part you want to broach before you put both into the press, the first few teeth in the broach will actually "skip" and the whole thing won't require as much clearance. Not guaranteed to work (also depends on material and hole tolerance) but something worth trying at least. |
A larger press is the ideal approach. You're not going to find a shorter broach.
We ran into the same problem this year. Our temporary fix was to create a secondary press platform below the one on the press (we have one like this that lets us pass longer material through the bottom of the press.). We'd put the material on the secondary platofrm, press as far as we could go, then the broach would be far enough into the press that we could use the original platform to finish the job. I hope I described that correctly. Just remember that if you do this, it's important to make sure your secondary platform is parallel to the original platform so you don't broach crooked. |
Could you possible post a picture of the setup you guys made? We tried it yesterday and realized that the lower platform has to be attached to the press and not to the table where it all sits, otherwise the press just lifts up when broaching. |
I keep our broach at work where I have a big enough arbor press. Broaches are very brittle. They need a straight push. The right size press is really the best.
It would help if you could provide more details such as the dimensions of the press and broach. if the dimensions are close, and if you have a lathe with a 4 jaw chuck, you can bore a hole into the ram of your arbor press to fit the back of your broach. I also suggest squaring the bottom of the hole with a modified drill bit or end mill. This and the amount of broach that starts in the part you are going to broach can give you an extra couple of inches.
Ken EDIT: The amount of load we put on the part+tool when they are in the lathe is very small - just enough to start 2-3 teeth of the broach - which is enough for it to then fit in our press. Last edited by Ken Patton : 03-06-2016 at 19:50. Reason: additional info added regarding load on the lathe, which is not recommended by some! |
#10
There is about a 6'' difference between the gap in the press and the length of the Broach, so it isn't really close to fitting ATM.
We will try both the Lathe broaching and the lower platform approach and post results here. |
#11
However the method of driving the Hex Broach, be careful with your fingers. As the broach passes through the part being broached, the tooth next to enter will take skin with it.
Have you been caught broaching in the classroom yet? ![]() |
#14
#15
Check out this thread for some ratcheting presses that are large enough for a 1/2 hex broach. I have a post on there on how we got the very sloppy Harbor Freight 12 ton shop press to work well with some simple mods. We really do need to find time to make a video of it in action.
-matto- |
