Go to Post the always so humble metal-in-motion.....i know your tricks; you all are gonna have a killer robot as usual.... - Stephen Kowski [more]
  #31   Spotlight this post!
Unread 07-06-2016, 05:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: HEX broach too big for our manual press
Originally Posted by Dpaulson View Post
I have been doing shafts and broaching a long time. We always start the hex broach in the lathe with the piece in the chuck and a center in the tail stock.As we get 3 or 4 inches in we move to the arbor press but I find no problem doing the process in the lathe. Drill a big hole a lot more force then the broach. Yes arbor press is fine for broaching a keyway but that hex broach has to be straight Most of this work is in alumimun
Dave Paulson
15 years mentoring
Team 599
You should look up brinnelling. This is really bad for your spindle bearings, regardless of whether you've noticed damage or not. All thrust bearings are designed to handle loads only while rotating. It's not relevant that drilling a large hole requires more force (which is debatable), since the bearing is designed to handle that load case.
2001-2004: Team 100
2006-Present: Team 254
