Go to Post You play your best, the refs do their best, and at the end of the day we are FIRST, collectively. - KenWittlief [more]
Unread 07-06-2016, 11:19
s5511's Avatar
s5511 s5511 is offline
FRC #5511
s5511 is an unknown quantity at this point
Pneumatic Solenoids
Which pneumatic solenoids/manifolds does your team use on the robot?
We used these (http://goo.gl/WDyuAw) last season, but they took up a lot of room on the robot.
Also, what tips do you have for preventing pneumatic leaks on the robot? We experienced many last season.
NC Rookie All Star, Rookie Highest Seed 2015
NC THOR Winner 2015
NC Guilford County Winner and Creativity Award 2016
Unread 07-06-2016, 12:02
qscgy's Avatar
qscgy qscgy is offline
The Last Airbender of 449
AKA: Sam
FRC #0449 (Blair Robot Project)
Team Role: Mechanical
Rookie Year: 2014
qscgy will become famous soon enoughqscgy will become famous soon enough
Re: Pneumatic Solenoids
We used these. Festo 12V VUVG series solenoids are quite reliable and easy to mount compactly; we just stacked them together and put bolts through the mounting holes. They are pretty flat, so even if you don't mount them together, they will almost always fit somewhere.
As for preventing leaks, we just make sure to keep tubing away from anything sharp and make nice, smooth, 90 degree cuts when cutting tubing. Utility knives work well for this; the trick is to just push down, not saw. If you start with tanks pressurized, you can catch leaks before a match.
Unread 10-06-2016, 12:37
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
90 degree cuts, you say?
There is no better tool than this puppy. It's the TC-12 pneumatic tubing cutter and you will not be disappointed by it. Every team should get one.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 10-06-2016, 14:08
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Actually, If you see us (AutomationDirect) at an event we are usually giving them away. In the past we have included one for free in every box of parts ordered via the AutomationDirect FIRST Voucher. I assume we'll do it again next year ...
Unread 10-06-2016, 15:23
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
Team Role: Coach
Rookie Year: 2011
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
The Festos are great - unless you need volume, say, for a ball launcher with a couple of 1.25" diameter cylinders. Then, they fail miserably compared to a valve like Automation Direct's:
http://www.automationdirect.com/adc/...9/AVS-3211-24D
The Festo VUVG has a Flow rating of 0.22 Cv (220l/min) vs. the
Automationdirect's Cv=0.78. The numbers speak volumes (pun intended).
Further, Automationdirect charges a fair price for pneumatic components rather than what they can get away with... compared to - ahem - some other suppliers. On top of that, they give FRC teams a free voucher every year, and always offer free shipping > $49.
No, I do not have any affiliation with Automationdirect - I merely appreciate what they provide to FRC.
Other thoughts: Be sure that whenever you remove a hose from a fitting that you snip off a bit, so that the fitting barbs can get a fresh bite. Also, leave air pressure in the system after matches to insure you have no leaks - and if you do have one, use soapy water applied with a small brush to find it.
A pneumatic cylinder pushed our ball into the shooter this year, and we chose to not have an on-board compressor. Through diligence and constant monitoring, we never ran out of air on the field.
Unread 10-06-2016, 16:36
chrisfl chrisfl is offline
FRC #1991 (Dragons)
Team Role: Leadership
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Those AutomationDirect cutters are handy. I picked one up at worlds and never had a problem with leaks from tubing. I am working on my highschool capstone project(which relies heavily on pneumatics) and the AutomationDirect's deals were the best. Especially for our extremely limited budget. I already have solenoids and a manifold from them coming in the mail. For the project we are developing pnuematic muscles which will then be used for actuation on an exoskeleton we are making. Our first prototype for the muscles was 1/2in in diameter and lifted 70+lbs at 100psi. To lower the working pressure to make them more safe we are increasing the diameter to 3/4in which should allow us to lift 50+lbs with 50psi. All in all, Automation Direct is a huge help with their reliable products and reasonable prices.
1991 2015-present
Unread 07-06-2016, 12:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We used the VexPro solenoids this year, two singles and a double. The manifold-based system did save a good bit of space over separate units.
In addition to using a modest amount of thread tape on fittings without washers, make sure that the tubing is cut perpendicular to the length. Beveled tubing cuts lost us a lot of air in our early years.
Unread 10-06-2016, 09:22
s5511's Avatar
FRC #5511
Are there any other manifold-based systems other than the VexPro line? I've seen teams using other ones, but I'm not sure what they are called or where they are buying it from.
NC THOR Winner 2015
Unread 10-06-2016, 12:08
spebow spebow is offline
FRC #2877
spebow is an unknown quantity at this point
Team 2877, the Ligerbots, We use a manifold for most of our solenoids. It saves a ton of space and makes everything easier. Also, if you are worried about space, we have found that wiring cylinders that act together up to one solenoid helps a lot. Our gearbox shifters, opening and closing our intake, and our double CDF/Portcullis wedges all used one solenoid each even though each of them used two cylinders. http://www.vexrobotics.com/solenoids-and-manifolds.html. This is the link to the solenoid and manifold that we use. In addition, this year we used a high flow cylinder for our pneumatic catapult shooter from McMaster Carr.
Unread 10-06-2016, 17:07
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Originally Posted by spebow View Post
+9001
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 10-06-2016, 17:40
adciv adciv is online now
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
If we need high flow rate, we use the ones from Automation direct.
If we need compact ones we use TDKs or Festos.
If we need bulk we use SMCs (see VexPro) on a manifold.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 12-06-2016, 09:33
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
One little tip, while it may be tempting to go with single (sprung) solenoids only (to save on channels) think about what happens in an e-stop/disabling.
If you use a single acting solenoid on a large arm or mechanism, then disabling can result in that solenoid shifting back into it's default position, and it's arm/mechanism flying back as well. This can pose a hazard :O
People expect a robot to stop moving when it's disabled, not all the pneumatics to retract.
We do however use single solenoids on internal mechanisms that are either low risk (eg shifters), or stay in one state for the majority of the time (eg latches).
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
