Go to Post Watch out, guys, Lisa's coming.... worse than any hurricane or tornado you can imagine! - KathieK [more]
Unread 15-06-2016, 08:24
stavinski's Avatar
stavinski stavinski is offline
FRC #2231 (Onyx Tronix)
Team Role: Electrical
Rookie Year: 2011
stavinski is an unknown quantity at this point
Replace the power wire in the talon srx
Hello!
we have a talon SRX that has very short power cable (somebody cut it very short) except of connecting to it an extension cable , is there a way to replace the wire?
Thanks,
Stav
Head of Electronics
Onyx Tronix #2231
Unread 15-06-2016, 09:17
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Replace the power wire in the talon srx
Originally Posted by stavinski View Post
...somebody cut it very short...
Somewhat off-topic, but it might serve a teaching purpose for other teams: why did somebody cut it very short? And what (if any) process changes has your team implemented as a result?
Unread 15-06-2016, 09:36
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Take note of the 2016 rule:
R66 The Driver Station software, roboRIO, Power Distribution Panel, Pneumatics Control Modules, Voltage Regulator Modules, RSL, 120A breaker, motor controllers, relay modules, Wireless Bridge, and batteries shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, rewiring, disassembling, etc.), with the following exceptions:
M.Devices may be repaired, provided the performance and specifications of the device after the repair are identical to those before the repair
That said, if you open up your Talon, you'll see where the wires get soldered onto the board, and it should be possible, in theory, to de-solder one and solder on another.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 15-06-2016, 10:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you have the proper wire, it's easy to do a replacement. We had to resolder one of the motor output wires on the Victor SP we got for early testing, and a Talon SRX is essentially the same.
It's not exactly trivial to replace the wire; you need an appropriately hot soldering iron (or gun), and you need to have good soldering technique to do it well.
Unread 15-06-2016, 14:54
DonRotolo's Avatar
Back to humble
FRC #0832
This.
But as Alan said, it is possible but you should take PAINS to ensure this never happens again. Pains I say.
Unread 15-06-2016, 18:23
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Maybe contact VEX/CTRE and see if they're willing to replace the leads for you?
Originally Posted by Mike Copioli View Post
If there are any teams that have Talon SRX's or Victor SP's that need the leads replaced send them back to us. We will gladly replace the leads.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
