Go to Post Just goes to show that you don't need to be like everyone else to make it to Einstein. - O'Sancheski [more]
Unread 16-06-2016, 16:02
yedidya03 yedidya03 is offline
FRC #3211
yedidya03 is an unknown quantity at this point
build failed - build.xml class not found
I tried to compile my project in java and I have got :
Buildfile: C:\Users\FRC3211\Documents\2016 frc season\java_robot_programming\FirstRobotProject\bu ild.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\FRC3211\Documents\2016 frc season\java_robot_programming\FirstRobotProject\bu ild
compile:
[mkdir] Created dir: C:\Users\FRC3211\Documents\2016 frc season\java_robot_programming\FirstRobotProject\bu ild
[echo] [athena-compile] Compiling src with classpath=C:\Users\FRC3211/wpilib/java/current/lib/WPILib.jar:C:\Users\FRC3211/wpilib/java/current/lib/NetworkTables.jar: to build
BUILD FAILED
C:\Users\FRC3211\wpilib\java\current\ant\build.xml :71: Class not found: javac1.8
Total time: 1 second
someone knows what is the problem?
Unread 16-06-2016, 17:27
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: build failed - build.xml class not found
Do you have Java 1.8 installed?
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 16-06-2016, 18:15
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Two things:
1. Have you installed JDK? In other words, did you following the "Getting Java" section in the following doc?
https://wpilib.screenstepslive.com/s...eclipse-c-java
2. Also, did you following the section "Setting up JDK in eclipse" section of the above doc?
In general, take a look at the above doc and make sure you have followed the instructions to get everything set up. The error you have means eclipse doesn't know where to find the Java compiler. So either you haven't installed it or you haven't told Eclipse where to find it.
