Go to Post "The compressor is half the temperature of a toasted Subway sandwich." - Ashley Hartley [more]
Unread 18-06-2016, 07:20
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: pic: OmniSwerve chassis Bottom View and Concept Discussion
It's summer. No pressure. No time constraints. Why waste your time on this project. Isn't there something your team needs to work on to improve it's skill set? Something that could actually be used in the future?
Unread 18-06-2016, 07:52
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Rookie Year: 2010
Scott Kozutsky will become famous soon enough
This was entirely my own project and an excellent opportunity to brush up on CAD. I figured Chief Delphi posters in general would also enjoy this kind of thought exercise but apparently not.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 18-06-2016, 12:37
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
The sqrt(2) speed increase is certainly a different way to think about things. I imagine it wouldn't coast terribly far on the rollers, and it's not powered through any obstacle in that direction. And sounds like you've considered how it would mess with the driver to be in a constant uncontrollable powerslide.
Put in a traction wheel and you've got a decent crab drive. Two more turning motors for unicorn.
Unread 18-06-2016, 12:44
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud of
On the contrary, I think this is really cool! The way you have thought past everyone's initial "why" to discover some really novel performance details shows that you have the creativity, and deep thinking a robotics team needs.
I spent some time last year thinking about a wheeled version of a cyclorotor for similar ridiculous reasons
Unread 18-06-2016, 15:25
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I also enjoyed the thought exercise of looking at the drive and working out the probable advantages/disadvantages of its distinctive constraints, even if no one could come up with enough advantages to want to build it.
I wish we had a few team members "waste time" this summer developing CAD skills.
Unread 18-06-2016, 19:20
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
There's never any reason to not mess around with CAD for practice, so it's awesome that you've done this. I'm hoping to post several oddball/silly designs over the next month, as soon as I get off my butt and get to CAD-ing. But great job on getting the ball rolling with off-season designs.
As for the design itself, it might be really interesting to lock the back two wheels in the forward direction, and then replace the forward omni wheel with some sort of traction wheel with VERY high amounts of scrub (or even a small tread module). Theoretically, if the forward steering module has enough friction against the carpet, powering the motor on the front steering module would actually turn the entire chassis in relation to the front wheel. With the front wheel pointed in a different direction from the back wheels, it might steer similar to a front wheel drive car, but without the need for a differential since the back Omni's can be powered at different speeds.
Unread 19-06-2016, 21:42
FRC #0865
Rookie Year: 2010
Unread 19-06-2016, 21:44
Moskowapplepi's Avatar
Moskowapplepi Moskowapplepi is offline
FRC #2067
Moskowapplepi is an unknown quantity at this point
I am curious how well this would work in practice as well as how the triangle design came to be.
Unread 19-06-2016, 22:03
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
Rookie Year: 2011
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Relevant thread/threads.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 19-06-2016, 22:41
FRC #0865
Rookie Year: 2010
The triangle design is a byproduct of maximizing motors and minimizing other complexity. Minimum amount of wheels to be fully supported is 3 and maximum reasonable amount of CIMs is 6. It also ensures all the wheels are in contact with the ground. 4 CIM 4WD would end up weighing about the same, be more mechanically complex and less powerful.
Unread 22-06-2016, 23:53
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
With the max speed thing, here was the way I though you could possibly do it:
Have one wheel face one way, another face 90* from it, and the third point right in between. If you power the two at 90* to each other, you'd get sqrt(2) the speed.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 23-06-2016, 00:48
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
The velocity vectors don't add like that I think. You would get sqrt(2) + 1 times the torque of the single cim pointing in the right direction, but the max speed is still only the speed of that cim.
<Now accepting CAD requests and commissions>
Unread 23-06-2016, 08:46
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
The velocity vectors can add up so that the speed of the robot is greater than the speed that any individual wheel is driven. The issue is that with the number of rollers providing resistance to this motion, I find it unlikely that those two motors could achieve a significantly greater speed than one in which all three motors are providing drive force in the desired direction. The only way to know for sure is to build it.
Unread 23-06-2016, 15:02
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Well, if you take the two non-pointing-in-the-right-direction motors and give them each an angle theta away from the main wheel...
If you assume velocity vectors add, then the output speed is (cos(theta)+1)*v0, right? If that's the case, as theta goes to 0* (AKA point all whee;s in the same direction) one would end up with just 2 times the target speed- but all the wheels are just pointing in the same direction like a tank drive. That doesn't make sense to me, is there another way to add it?
  #15   Spotlight this post!
Unread 23-06-2016, 16:02
on walkabout
Force vectors add. Velocity vectors do not. Rather they are constrained by slip conditions and the relative motion of bodies.
It's sort of a continuously variable transmission.
Say you are constrained to go in a direction 0 (by a wall or omnis opposing each other, etc.), but an omni wheel is pointed in a direction theta relative to your heading, and spinning at speed w about its axis. The overall translation velocity vector v is identically the velocity of the center of the wheel relative to the ground, which can be broken into the rotation of the wheel (w), and the rotation of the rollers (s), assuming no slippage. Then v must project onto the wheel speed w, as w=v*cos(theta). The roller speed is s=v*sin(theta) and has no limit. The overall speed is v = w/cos(theta), resulting in a higher speed.
To do this, you could have a four wheel drive with steerable omnis in each corner. Start with them directed forward, (theta=0), and spin the wheels at speed w. Then v = w / cos(0) = w. Then turn the left and right wheels toward the middle by an angle theta. Now v = w / cos(theta) will give an increase in top speed.
However, the force available in the forward direction drops. Each wheel supplies F in its own direction. When theta = 0 then the total force is 4*F, all straight forward with no sideways component. When theta is increased, the sideways components cancel, but at each wheel, the sideways component must add with the forward component to get F in the direction theta. So the forward component from each wheel is F*cos(theta), and the overall force available is 4F*cos(theta).
In this way, steering the wheels toward the middle by an angle theta acts as another stage of reduction, increasing the speed and decreasing the force by a factor of cos(theta), assuming no wheel slippage.
Vector diagram to help
