Powering an FRC-like system from a wall outlet
We're building a simple linear motion mechanism that we'd like to be able to plug into a wall to use. I don't have much experience with electric systems, so I was wondering what might be a good way to go about that. The requirements we have are listed below:
1) Powering a mini-CIM with amperage needs consistent with moving a load of about 20 lbs along a horizontal track at ~20in/sec (25:1 Versaplanetary reduction) with little friction. 2) Using a Spark motor controller 3) Needs to plug into a standard American wall outlet Thanks! |
Re: Powering an FRC-like system from a wall outlet
Depending on your current requirements, something as cheap/simple as a used PC Power Supply might be everything you need.
+1 on PC Power Supplies. Large 12v supplies are also available from places like Ebay for cheap. I got a 12v 15a power supply with several outlets for only $30, and the bigger you go the cheaper it gets per amp (to a point).
Another fun bit about using PC Power supplies: You can use the 5v rail for something like an Arduino, which keeps the control system cost down, and removes the need for extra regulating circuits.
Hi Eric,
I’ve inputted the numbers into the Linear Motion page of the JVN calculator, and it seems that the Mini-CIM isn’t going to draw a huge amount of current. The calculator gave an answer of around 8-10A( this is lifting the 20lb vertically not horizontally). As long as you don’t intend intend to stall the mechanism or increase the load or speed, a 12v 20A power supply such as this type should work nicely for you: http://www.ebay.com.au/itm/like/1719...pid=107&chn=ps You should also be able to use an old computer power supply if you have one around. A 350watt PS( if you have a more powerful one use that) should be able to give out 16A on one of the 12v power rail( just look on google to find a chart of the power rail colours). If you need to, you’ll also be able to power any control system parts of the other rails of this computer power supply as well. The Computer PS will be able to power the C-rio, Robo-rio, RPI or Arduino etc. that you use for generating the PWM signal for the SPARK, which should simplify things for you( again look up the PS on google to find a chart of rail colours and voltages) Last edited by pilleya : 21-06-2016 at 18:14. |
Is it possible with this unit to have a line going out to the motor controller and then convert another line to 5v to power the control system? |
If you're running off a switching supply, I would make sure to ramp the control to prevent doing 12V stall of the motor.
#10
The AC terminals are exposed, please use a great deal of caution when working with the AC. Stay safe! Last edited by pilleya : 21-06-2016 at 19:25. |
#11
Edit: There could be capacitors inside of the power supply that will keep power going to the high voltage terminals even when unplugged, though they shouldn't if everything is wired properly. Last edited by ctt956 : 21-06-2016 at 20:13. Reason: Forgot the capacitors |
#12
Beware of using a PC power supply. Many required balanced 5V and 12V loads to get advertised current outputs, meaning you'll have to throw some big resistors on your 5V rail.
#13
Get yourself a couple server PSUs. http://www.rcgroups.com/forums/showthread.php?t=1292514
I use a HP DPS-600PB to power a 2200 W (peak) brushless spindle for my CNC router. Works great! |
#14
