pic: 2x 15mm HTD Belt Pulley
Re: pic: 2x 15mm HTD Belt Pulley
I am guessing this is going to be used for belts in tube drive.
Is the countersink to let the bearing rest inside of the pulley and not need any spacing away from the tube ? We have done that the last 2 years and it works out great. The bearings help hold the pulleys in place while you set all the belts in and hold them in place with hex shaft. Once in place we have not touched it or made any adjustments the last 2 seasons. |
See this post: https://www.chiefdelphi.com/media/photos/43873? |
Neat concept - worth trying out. Where would one get 5mm HTD pulley stock?
You can get GT2 pulley stock too, which is compatible with GT3 belts. GT3 belts, while more expensive, are twice as strong as HTD belts of the same size. You can check out that discussion here: https://www.chiefdelphi.com/forums/s...hreadid=149109 |
If you're already going to SDP-SI for pulley stocks, might as well go for GT2 pulleys and GT3 belts.
