Go to Post The worst that happens is we try our best and lose. And there's no shame in that. - pfreivald [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 22-06-2016, 14:58
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
pic: Another Belt-In-Tube Drivetrain
Unread 22-06-2016, 15:11
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: pic: Another Belt-In-Tube Drivetrain
I love this thing! Very clever to counterbore the pulley so that it can use the full width of the tube.
Looks super compact and lightweight, and above all very clean, great work. Interesting that you used OnShape for this, I have a few friends who love it or hate it.
<Now accepting CAD requests and commissions>
Unread 22-06-2016, 17:47
Robotics Engineer
Thanks. I'm a little bit concerned about the lack of flanges on the pulleys, but with less than .035" of space on either side I just couldn't fit them in. That said, the .035" is small enough to let the tube wall be the "flange" if anything goes wrong and the belt tries to walk.
As for OnShape, I've expressed my thoughts here.
Unread 22-06-2016, 19:59
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
2 inch square .125 wall 6061-T6 is readily available ( On-line Metals, et al). Seems like this would eliminate machining of cots parts, and potential rubbing of the belts.
It seems like many teams just use 1.5x2, but there's no need to constrain yourself to it.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 22-06-2016, 22:23
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
I would think the reasoning is to save space rather than just fit the belts in the tube. Losing 1" of width doesn't seem like a lot, but especially for this year that 1" would have been the deal breaker for me.
Unread 23-06-2016, 07:28
Robotics Engineer
Saving space is nice, but my main reason for designing this was an exercise in whether or not I could fit a belt-in-tube drivetrain with 15mm belts into a 2x1.5. When I have the time (aka, offseason) I like to give myself tight constraints in an effort to force myself to think outside the box.
(or inside the tube... eyyyyy)
Unread 23-06-2016, 07:55
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Unread 23-06-2016, 09:17
Chris is me's Avatar
AKA: Pinecone
If you're doing 15mm belts with a single pulley, you already have to machine your own pulleys from stock. You also already want to leave a nub on the pulley to touch the inner race of the bearing. So adding the counterbore for the bearing isn't THAT much harder, and it makes the entire chassis more compact to do it this way.
The extra inch of space really does help sometimes.
Unread 23-06-2016, 09:28
Sh1ine Sh1ine is offline
FRC #2791
Team Role: Leadership
Sh1ine is on a distinguished road
How do you plan to attach your belly pan to this setup? We use belt in tube and I have wanted to go to a smaller tube but I always worry about the rivets rubbing the belt.
An alternative to pocketing the belts is to add .125" thick washer (spacers) to the bearings before putting them into the tube, that makes them flush with the interior or the tube.
Unread 23-06-2016, 09:42
Robotics Engineer
We're fortunate enough to have the ability to weld our belly pan on. You could get clever with staggering your rivets for your belly pan as the belts only take up one side of the tube between the pulleys, but it would make it almost impossible to disassemble if you needed to.
Unread 23-06-2016, 09:43
Flywheel Police
Everywhere there is a hole it is safe to mount to.
Unread 23-06-2016, 10:34
Robotics Engineer
..snip...
what if you have to pull the chain/belt out of the tube?
Unread 23-06-2016, 10:39
Flywheel Police
Unread 23-06-2016, 14:58
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Wouldn't you just pull the shafts out and pull them out that way? I always thought that how everybody did it. You can pull them out to avoid the rivets pretty easily, I would think, especially given that you only have 2 belt runs in a tube.
  #15   Spotlight this post!
Unread 23-06-2016, 15:05
AKA: Pinecone
Are you saying to pull the belt out through the bearing hole? That's kind of a tight fit.
Regardless, I think this is mostly an academic exercise - this particular belt in tube configuration has by now been battle tested on dozens of FRC robots without failures. It's a very reliable drivetrain.
