Go to Post Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it. - Isaac501 [more]
Unread 25-06-2016, 12:43
balloman balloman is offline
Sophomore Programmer
AKA: Bernard
FRC #0034 (Rockets)
Rookie Year: 2016
balloman is on a distinguished road
Network Tables with c++
I have vision code in c++ that I would like to send to the roborio with network tables. My only problem is that there are no tutorials on the wpilib website to do this in C++.
Unread 25-06-2016, 13:35
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Network Tables with c++
https://www.google.com/search?q=networktables+c%2B%2B
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 25-06-2016, 14:54
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
I'll assume your C++ project is not built with WPILib.
First, git clone the NetworkTables repository: https://github.com/wpilibsuite/ntcore
Then build it for whatever you're running this on (arm or native) with gradle. See the readme file for how.
Then, find the static library file for whatever you built it for. For example, a x64 native build would be located at ntcore\native\build\binaries\ntcoreStaticLibrary\x 64\ntcore.lib
Also find the includes folder at ntcore\include
Now you're ready to use it in your C++ project. Add the includes folder as an include path, the folder containing ntcore.lib as a library path, and tell the linker to use ntcore as a library (-lntcore on GCC)
Then in your cpp file add these includes
Code:
#include <ntcore.h>
#include <networktables/NetworkTable.h>
Documentation for NetworkTable is included in WPILib documentation here: http://first.wpi.edu/FRC/roborio/rel...workTable.html
For example, to publish a string value to the roboRIO's SmartDashboard you can do
Code:
#include <ntcore.h>
using std::shared_ptr;
int main() {
    NetworkTable::SetClientMode();
    NetworkTable::SetIPAddress("10.te.am.2");
    NetworkTable::Initialize();
    shared_ptr<NetworkTable> myTable = NetworkTable::GetTable("SmartDashboard");
    myTable->PutString("ExampleString", "Sample Text");
    NetworkTable::Shutdown();
    return 0;
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 26-06-2016, 02:24
AKA: Bernard
FRC #0034 (Rockets)
Rookie Year: 2016
Code:
#include <ntcore.h>
Code:
#include <ntcore.h>
int main() {
    return 0;
Thank you so much, this is exactly what I was looking for. I kept searching on google BEFORE I posted this, but couldn't find anything.
