Go to Post “Hey, why are those numbers showing, it must be a game hint!” Listen, please – it’s not a game hint. Our game hints typically start with something like “This is a game hint!” - Frank - pwnageNick [more]
Unread 28-06-2016, 19:05
marcusbernstein's Avatar
marcusbernstein marcusbernstein is offline
Pool Noodle Thrower
AKA: Marcus Bernstein
FRC #1836 (The Milkenknights)
Team Role: Leadership
Rookie Year: 2013
marcusbernstein is just really nicemarcusbernstein is just really nicemarcusbernstein is just really nicemarcusbernstein is just really nicemarcusbernstein is just really nice
Hole Patterned Tube Generator
Using Openscad and the Thingiverse customizer feature, I was able to create this resource to easily create 3d models of hole patterned tubes. Essentially, Thingiverse allows users to make calculators that generate 3d models based on user input of specific variables, rather than make the entire model over and over again. This feature can be very useful because it allows many similar files to be made at once, rather than individually modeling a bunch of parts that have minuscule differences.
The 3d model generator that I created can be found here:
http://www.thingiverse.com/thing:1649104
Once you open that link, hit customize and you can make your own hole patterned tubes quite easily (even without knowledge of 3d modeling).
Has anyone else made 3d model generators like this one? Does anyone have any ideas for other generators I/someone else should make in the future?
Keep in mind when testing that this is just my first version, and I plan on adding more functionality/fixing bugs in the future. If you have any questions, comments, notice any bugs, or have any recommendations for more features please let me know.
Unread 28-06-2016, 21:14
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: Hole Patterned Tube Generator
Solidworks has a pattern tool, and I assume other CAD software are similar. How is this method better/different than just modeling it from scratch?
Unread 28-06-2016, 21:36
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Or making a template of sorts within CAD by copying the part file and changing the parameters
Edit: At least in Inventor, there is a thing called iParts that I believe has exactly what you made built in and with more versatility.
Unread 28-06-2016, 21:55
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Speed. I use an IPart Generator in Autodesk Inventor to make about 80-90% of the tubing I use. Its about 10-15x faster to enter a few numbers and select from a few drop down menus than draw the tube and and add a hole pattern. Part generators also have the benefit of reducing errors in dimensions, material selection and hole sizes.
Inventor also has a design accelerator called frame generator that allows you to create a custom profile and apply it to a 3d sketched outline of whatever you are designing. Essentially rather than designing a chassis as 10-25 pieces it can be designed as 1 sketch and then pick different pieces of tubing at the assembly level to fill it in instead of making each individual piece and having to constrain them into the final frame.
I also use iPart generators to procedurally generate any thunderhex shafts in my CADs with drop down menus for snap ring groves, 1/4-20 threaded ends, bearing rounds, and .25 diameter end holes for encoders.
iParts do exactly that. But they do have the downside of not allowing you to put the cut length in the part name at the time you create the file.
Past teams:
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 29-06-2016, 15:26
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
SolidWorks will do this without math or equations as of 2015. Any linear pattern of any length can be updated dynamically. Even before 2015 it could be done with a short equation but now it is automatic when you use a reference selection.
https://www.youtube.com/watch?v=oFET92LqgyM
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 29-06-2016, 16:52
Pool Noodle Thrower
Rookie Year: 2013
Thanks guys for all of your input. I didnt actually know that there were so many other ways of doing this in Solidworks (besides just making a tube and hole patterning). I am going to look into those and play around with them so I can make templates/generators withing Solidworks. Either way, this tool could prove useful for people who do not really know how to CAD on such a high level (for example me).
