Go to Post The question was asked. The GDC gave their ruling. If you don't like it then maybe you can run your own tournament and let people ignore your rulings. - Daniel_LaFleur [more]
  #16   Spotlight this post!
Unread 06-07-2016, 11:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Good way to bring shooter to exact speed?
Originally Posted by Ether View Post
Because Y is the output to the motor controller, and the integration of Y is always in the direction to drive the speed toward (and then past) the setpoint... which causes a change in the sign of "e".
Ok, that's not how I had read the original thread. Looking back at it I must have misread:
The hallmark of TBH is the unique way that the output is reset at each zero crossing.
as
Originally Posted by Not-Ether
The hallmark of TBH is the unique way that the output is only reset at each zero crossing.
Thanks for the clarification - this will save me a whole bunch of heartache as I experiment with TBH on a motor driven launcher.
