Go to Post We can build it... we have the technology...better than it was before... Better...stronger...faster.... more PINK - Barry Bonzack [more]
Unread 08-07-2016, 22:31
DrewMatic's Avatar
DrewMatic DrewMatic is offline
Djibouti
AKA: Drew T
FRC #0240 (T.E.M.P.E.S.T)
Team Role: Leadership
Rookie Year: 2014
DrewMatic is an unknown quantity at this point
Chain vs. Belts?!?
Hey everyone. I'm from team 240 T.E.M.P.E.S.T.
The past 2 years we have used chain everywhere. There was one thing that happened, we had to fix the chain a lot more than we liked too. I know this could be due to poor alignment, etc. but next year we plan on using belts.
What are your thoughts on Chains? Belts?
Thanks, Drew
Projects we have completed demonstrate what we know, but future projects decide what we learn.
Unread 08-07-2016, 22:36
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Chain vs. Belts?!?
This is a topic that is discussed quite often.
There is a good white paper written by team 234 which evaluates the power transmission methods:
https://www.chiefdelphi.com/media/papers/2216
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts. REDBOX(gearbox for the throttle motor)
Facebook
Unread 08-07-2016, 22:37
DrewMatic's Avatar
Djibouti
AKA: Drew T
Rookie Year: 2014
Thank you! I'll check it out
Unread 08-07-2016, 22:39
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Its worth mentioning that if the issue was alignment whether you are using chains, belts or interlocking plastic monkeys the issue wont be solved.
If you are using #25 chain and there are alignment issues switching to #35 could help but really the best thing to do is fix the alignment.
If your issue has to do with master links I would buy a dark soul chain remover.
iirc belts actually are more sensitive to being out of alignment so switching to belts is only going to make things worse.
Unread 09-07-2016, 12:04
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
QFT.
If alignment or tolerance is what is causing you problems now, switching to belts will make the situation much worse.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread 11-07-2016, 14:05
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
We successfully used a Polycord drive system in the past. One of the center wheels was direct driven by a custom super shifter based gearbox. The other wheels are all direct driven by Polycord using custom pulleys directly attached to the wheels (Dead Axles). This is the best picture I could find of the drive train. (This is one of our signature Round Robots)
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 11-07-2016, 14:17
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Attachment 20906
Out of curiosity, what year was it? Also, did you have any problems with the polycord slipping in shoving matches or other high-torque situations?
Disclaimer: All references to rules and legality are from current or past seasons and it should not be assumed that any rule will remain the same in future seasons.
Unread 11-07-2016, 16:12
InFlight's Avatar
AKA: Jim
Rookie Year: 2012
That was the 2014 season, Our Jupiter Robot. No real noticeable issues with belt slip.
Here a match from that season with plenty of pushing.
http://www.thebluealliance.com/match/2014pncmp_qm41
Unread 11-07-2016, 16:17
ASD20's Avatar
AKA: Andrew
Rookie Year: 2014
Wow, I never would have thought that polycord would work in a year like 2014. I'm impressed.
Unread 11-07-2016, 14:22
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
There's no single correct answer (despite what some CDers would say) of what you should use. It all depends on your situation. If you need the weight, you may need to go with belt. If it's going to be a giant PITA to change a belt, you may need to go with a chain.
In my opinion, the "default" choice, when nothing really matters, you just need a reliable drivetrain, is to go with #35. It doesn't break, it's dead simple, it's forgiving, but is heavy. However, the "nothing really matters" portion is rarely the case and each situation needs to be handled on a case-by-case basis. What is important is knowing the tradeoffs (which have been outlined pretty well already in this thread). I wouldn't, however, deviate from the "default" of #35 chain without a good reason. The good reason may be weight related or space related, but you should at least have one.
Unread 11-07-2016, 14:35
ASD20's Avatar
AKA: Andrew
Rookie Year: 2014
Agreed. My team has learned the hard way to just use #35. The way I like to think about it is that #35 is complete overkill for FRC, which is why its the best option for FRC. Since it is overkill, it is a lot harder to mess up and will just work, which is exactly what you want for a drive train. The question you should be asking whenever you use chain should be why should I use #25, not why should I use #35.
Unread 11-07-2016, 20:44
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
This year my team's robot had 8" wheels and 22t sprockets, which stressed #25 chain more than in any of our previous drivetrains, and had zero issues. On the other hand, we broke our #25 intake arm chains multiple times, and in the future we will likely use #35 chain for arm applications. At least for our team, we have found applications for both #25 and #35 chain.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 11-07-2016, 14:42
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Belt and chain weight is the same when you factor in pulleys/sprockets. That being said I 100% agree that #35 is bulltproof and should be used for a "first chassis" sort of deal.
<Now accepting CAD requests and commissions>
Unread 11-07-2016, 15:36
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Assuming you are using aluminum pulleys, the pulley/sprocket weight is probably close to a wash. Factor in 35 chain, the chain is a lot heavier.
Polycord will slip given enough torque. That is either a bug or a feature depending on your needs.
If you don't know what you should hook up then you should read a data sheet
  #15   Spotlight this post!
Unread 11-07-2016, 16:31
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
I was thinking about #25. For #35 nothing beats it in terms of weight.
EDIT: InFlight, that is a gorgeous robot and a great performance! I can't believe polycord drive worked that well.
