Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 10-07-2016, 19:51
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
pic: ABS-122, shifter-in-tube chassis
Unread 10-07-2016, 19:57
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: pic: ABS-122, shifter-in-tube chassis
It doesn't look like you have any form of chain tensioners on this setup. Although you can do without them, I would still really recommend putting them on even in the case of using large tooth count sprockets. We used a setup similar to this in terms of chain, and really wished we had designed a way to tension the chain during the season.
Unread 10-07-2016, 20:08
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
We used 16t #25 sprockets all season with only a single jump at SVR (and that was after another competition in Utah) and that was after the chain got very loose. It's possible to add tensioners in the form of versablocks or even WCP sliding bearing blocks, but I like the set-and-forget of direct C-C. Are you certain that your sprockets were correctly aligned? I'm guessing that they were and you guys just did much harder driving than us, but it never hurts to check.
With massive sprockets such as these I'm not as worried about the chain coming off as much as I am about the chain picking up tape. I could swap these out for #35 chain sprockets, but the extra weight isn't worth it to me. In-season if it became a problem switching to #35 chain would be my first choice.
<Now accepting CAD requests and commissions>
Unread 10-07-2016, 20:31
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
I'm really impressed with how compact this is. What size are those sprockets, by the way? I think you'll be fine leaving it at exact C-C, but since the chain is outside of your tube, it'd be easy to add a static tensioner after your first or second competition. Just for peace of mind you might want to print something that fits around or on the top of your motors to ensure the chain doesn't rub against the motors in the worst situations.
Unread 10-07-2016, 20:35
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Thank you!
The sprockets are 38 tooth versasprockets from Vex with a minor diameter of just over 2.8". They are inline with the CIMs, so I'm not too worried about the chain hitting. In the past 115 has used polycarbonate chain guards, so if there was a problem I would stick those in.
Unread 11-07-2016, 00:24
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
I like this. I think it would also be a neat way to do a single speed drive with a PTO, not super clunky like most PTO setups.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-07-2016, 00:49
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
I was thinking about making a PTO option of this. With the Versadog it becomes a lot easier too.
Unread 11-07-2016, 17:56
Cash4587's Avatar
Mentor
AKA: Cooper Cash
Team Role: Coach
Rookie Year: 2013
We never had issues with it slipping or jumping or breaking or ever coming off. We just find it very hard to write fast, accurate and repeatable autonomous modes with so much slack in our chain. It gives semi un repeatable results in our vision code when only the front 2 wheels move while the back 4 don't having to make up the distance in chain slack. It would have been much better to just run tensionors from the start.
Unread 11-07-2016, 19:31
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
I see, that's a good reason to run proper tensioning.
How did it cause errors/to what extent? If two wheels are moving, theoretically the whole bot should move anyway. Would direct driving the center wheel help?
Unread 11-07-2016, 21:56
Cash4587's Avatar
Mentor
AKA: Cooper Cash
Team Role: Coach
Rookie Year: 2013
So this year our robot had about 60% of our weight on the front wheels. Direct driving the center wheel or any wheel might have helped. We ran a single gear reduction 12-66t and then a 12-22 #35 chain reduction to the wheel. (We later switched from 12-22t to 12-28t and is much better) In our case, direct driving any wheel may have helped but we really enjoyed this setup. We would get no movement on our robot for about 1/8th of a turn on the back wheel to catch up in chain slack. The whole robot wouldn't move because we had tons of turning scrub also so I guess a few things would have helped. But in any case, the chain slack and slop in the hex shaft really was a pain when trying to tune our code. I guess that's why 971 goes through so much to get all of the slack out of everything and makes custom hex.
Unread 11-07-2016, 22:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
If 60% of your weight was on the front wheels, I would recommend (other things equal) that you drive the front wheels directly; this is ultimately the same reason that West Coast drives the center wheels directly - to make the drive to the most dependable wheels invulnerable to a broken chain/belt.
On the other hand, if 60% of my robot's weight were on the front wheels in a static configuration (and presuming I had at least six wheels), I would be VERY worried about the robot falling on its face in a braking maneuver.
Unread 12-07-2016, 00:18
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
That is completely dependent on CG height and, given 4587's short robot, probably not a major risk.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 12-07-2016, 01:56
Cash4587's Avatar
Mentor
AKA: Cooper Cash
Team Role: Coach
Rookie Year: 2013
We had #35 chain direct driving the first wheels. Given the strength of 35 chain, and the fact that we put the chains in line, as well as calculated the direct c-c we had no issue other than chain stretch which is to be expected. We had all 6 drivetrain motors above those wheels accounting for the rest of the weight minus the catapult and battery.
With this being said. After 2 regionals, Champs, and an offseason already we never replaced 35 chain, or 25 chain. We were never worried about it breaking either. It is just something that doesn't occur that often if chain is used correctly, which we did, just without tensioners. Which in our case worked very, very, very well, and in many cases would be fine for most every other team in FRC not wanting to do some of the precision complex things things we need to get our code really dialed in.
Unread 12-07-2016, 21:19
chrisfl chrisfl is offline
FRC #1991 (Dragons)
Team Role: Leadership
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Looking at the size of those tubes, would you be able to put the wheels inside them to maximize space used in the tubes? That would also allow you to move your side rails out more to create more space in the center of the frame.
  #15   Spotlight this post!
Unread 12-07-2016, 21:23
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Rookie Year: 2007
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
The two wheels directly driven by the gearbox have to be outside the tube as the gearbox is inside the tube already there. The other wheels could be put inside the tube, but that doesn't really do anything for you.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
