Go to Post These are the moments you will bring with you the rest of your life, enjoy them! - KathieK [more]
Unread 12-07-2016, 19:40
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Team Role: Mechanical
Rookie Year: 2007
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: Everything in the tube drive (too late to turn back now)
Unread 12-07-2016, 19:41
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: pic: Everything in the tube drive (too late to turn back now)
Looking at the wheel set-up, are you planning on making bumper mounts that will make a hexagonal drivetrain?
What's that bump in the middle where the gearbox is? What's holding the bearings near the shifter in? It doesn't have a flange, so it confuses me.
Assemby could be easier with some extra access holes to stick a pair of pliers in to hold stuff still.
Unread 12-07-2016, 19:51
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
I like your packaging much more than mine, but I can see why it would be impossible to assemble...
I'm seconding Chak's question about what the bump is. Did you mill down the entire outside of the tube except for that part?
EDIT: what size tubes are those?
<Now accepting CAD requests and commissions>
Unread 12-07-2016, 20:52
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
When you expand the drive rails to 2"x2" (which is my educated guess as those rail dimensions), how much space are you actually saving by going in tube?
Being correct doesn't mean you don't have to explain yourself.
Unread 12-07-2016, 21:23
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
Any reason you put the outer wheels on the inner edge of the tube and not the outside? Having them on the outside reduces turning scrub (slightly) and lets you extend your belly pan into the corners of the frame.
Though, having a hexagonal frame perimeter might make it easier to avoid pins.
Unread 13-07-2016, 00:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Methinks they are bull gears (final stage gears). I hope I'm wrong, but I see extraction of pulled carpet threads from gears in 2471's future.
Unread 13-07-2016, 01:04
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Rookie Year: 2007
My apologies for the slow response. I just got off work.
Something like that. I'm partial to octagons for ease of mounting.
Its flange is bolted to the inside of the tube to save space.
That's true, but I still think this design would take several lifetimes to put together, so I don't plan on ever building it.
Thanks, and yes I prefer that to a lightening pattern.
2" by 2" by 0.125" wall.
Not enough to be worth it. This design was half way between a joke about the "put everything in the tube" hype train, and a fun CAD exercise.
Yep, I mostly did it that way because the gearbox design allowed me too, and I like the bulged side drives.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 13-07-2016, 03:34
42!'s Avatar
42! 42! is offline
College Student
42! is an unknown quantity at this point
Have you ever used this technique in real life? Even if you have a facing cutter and a good size mill it would take a huge amount of time and resources. The same result could be achieved by bolting/riveting/epoxying/welding a reinforcement plate in the areas you need on some thinner wall tubing.
In general when working with square tubing it's a better use of resources to order a smaller size/wall thickness than to machine weight away from a thicker tube.
Unread 13-07-2016, 15:10
Chris is me's Avatar
AKA: Pinecone
Could I get a picture of your shifter shaft without any gears on it? Kind of curious how that works out, with the pulleys on either end and the shifter in the middle.
Unread 13-07-2016, 18:24
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Rookie Year: 2007
Yes, I have done this in real life. Admittedly to a tube smaller than the one pictured, but it did not take a lot of time or resources to do. Thinning the walls of the tube would be significantly stronger than bolting/riveting/epoxying/welding a reinforcement plate on, and would require less time and resources, because each side of the tube would have to be set up on a mill anyway.
Yeah... I wasn't able to come up with a solution that I really liked, but this is whats in the model:Picture
Unread 13-07-2016, 19:27
chrisfl chrisfl is offline
FRC #1991 (Dragons)
Team Role: Leadership
chrisfl is a jewel in the roughchrisfl is a jewel in the roughchrisfl is a jewel in the roughchrisfl is a jewel in the rough
Would you be able to put your front and back wheels inside the rails as well? That would utilize more space in them and maybe make the concept more valuable with as much space as possible being utilized
1991 2015-present
Unread 13-07-2016, 21:12
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Rookie Year: 2007
Great idea! I'm surprised I hadn't thought of that. I still don't think the design would have enough value to be worth pursuing, but putting the wheels in there definitely saves some space.
Here's the updated model:Picture
Unread 13-07-2016, 23:21
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Thumbs up Re: pic: Everything in the tube drive (too late to turn back now)
Now, what would it take to get the motors inside the tube? They are fairly high on the list of components that get in the way, so that should be a priority. (2.5" motors fit in 2" tubes, right?)
Code:
1.25*sin(x)=1
sin(x)=0.8
x=arcsin(0.8)
L=1-1.25cos(x)    //maximum length of remaining material (in inches), measured from
L=0.25            //edge of tube, assuming motor is centered
(Yes, they technically do.)
Unread 15-07-2016, 11:53
FRC #1991 (Dragons)
Code:
1.25*sin(x)=1
sin(x)=0.8
x=arcsin(0.8)
If you are really ambitious, I bet a few talons could fit in there too! Maybe an accumulator even.
1991 2015-present
  #15   Spotlight this post!
Unread 15-07-2016, 22:10
AKA: Alan Wells
FRC #1350 (Rambots)
While there are some that would fit, I think it would be more practical to keep the accumulators elsewhere. /S
On a slightly more serious note, there is still unused space in the front and back rails for possible manipulator or slide drive mechanisms.
Last edited by PAR_WIG1350 : 15-07-2016 at 22:18. Reason: More to say, didn't want to make consecutive posts
