Go to Post Kudos to you IFI, for your continued support of FIRST and its stated ideals - Racer26 [more]
Unread 13-07-2016, 16:46
mlantry mlantry is online now
I'm back
AKA: Matthew Lantry
Rookie Year: 2011
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
How do you make surgical tubing roller
After looking into different things can be done to make intake rollers I came across that many teams use surgical tubing on some kind of round stock. I am curious how in which teams make said rollers. Thanks
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 13-07-2016, 16:56
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: How do you make surgical tubing roller
I think those are actually made of poly cord instead of surgical tubing, or at least the ones I've seen. There's something similar at the bottom of this page. Is that it? If so, I think the poly cord is just wrapped around rollers, at least one of which is driven by a motor.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 13-07-2016, 17:01
I'm back
AKA: Matthew Lantry
Rookie Year: 2011
ment more like the roller 254 used to intake balls with this year and in past years
Matthew Lantry
Unread 13-07-2016, 17:10
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
We did a latex surgical tubing roller this year. Just a little bit of alcohol does it. A little goes a long way. The hardest part was trimming up the ends of the rubber without it sliding or looking like crap. To do that, we put the tube assembly in the lathe and very carefully trimmed the ends with a box cutter. Our intake was actually a 3-roller system with polycord running in grooves of the latex tubing (using #25 chain for power transmission), which fed right into our shooter.
Unread 13-07-2016, 16:58
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
I think they just force the surgical tubing on with some alcohol.
More information there:
https://www.chiefdelphi.com/forums/s...51#post1426351
Unread 13-07-2016, 19:25
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Make sure that whatever you are using as the base roller, such as a tube, is plugged at one of the ends. Attach your surgical tubing to an air hose nozzle using a zip tie or something. While blowing air(you will need to control pressure and flow) have a second person slowly push the tubing over the roller. Do not pull. Do not squeeze the tubing to tight if your hand is over the roller while pushing, it will turn into a balloon animal and pop.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 13-07-2016, 19:37
We didn't need any air at all for ours. With the rubbing alcohol, it slipped on quite easily.
Unread 13-07-2016, 20:03
RoboChair's Avatar
We used the above process to put 1" ID 1.5" OD latex tubing over 1.25" OD aluminum tube for our intake this year. As soon as you let off the air it is incapable of even being persuaded to move by use of force alone, you either float it some more with air or cut it off. It is very nearly a permanent installation method.
Unread 13-07-2016, 23:14
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Wow, with a difference of .25 diameter I would have expected needing epoxy or something. We used Polyurethane tubing this year much closer in size to our roller and ended up needing epoxy.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread 14-07-2016, 15:07
RoboChair's Avatar
Not 0.25" over, 0.25" interference fit. 1 inch ID rubber tube onto 1.25" OD aluminum tube.
Unread 14-07-2016, 16:37
Monochron's Avatar
Engineering Mentor
Ah, my reading comprehension needs some work
Unread 14-07-2016, 16:42
FarmerJohn FarmerJohn is offline
Pre-Rookie team
AKA: John Reynolds
no team (Turlock Titans)
Team Role: Team Spirit / Cheering
Rookie Year: 2016
FarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond repute
Did you find that this method changed the OD at all?
Unread 14-07-2016, 18:20
RoboChair's Avatar
It probably ended up between 1.625" and 1.700" OD overall, I'm not actually sure what it came out to. But it was for sure smaller than 1.75"
Unread 14-07-2016, 18:26
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Here is the exact latex tubing we used.
http://www.mcmaster.com/#5234k91/=13a807t
This is the aluminum tubing we used.
https://www.zoro.com/value-brand-tub...f7/i/G3344862/
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
  #15   Spotlight this post!
Unread 18-07-2016, 01:25
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Alternative method that is somewhat questionable.
We used a bicycle inner tube for our shooter this year - not the same as intake but equally difficult to attach.
We used the air method to get the inner tube over a piece of aluminum tube slightly larger than the un-stretched tube. We then rolled the tube up into a ring and removed it then used a 6 jaw lathe chuck to stretch the entire tube at once until we could fit the 4" aluminum drum in the middle of the chuck and roll the tube onto it.
Bicycle inner tube works really well, but you need to clean it with something that will get rid of the powder. We used soap and water before it was on and then wiped with a rag with brake cleaner applied since it eats away the top surface of the rubber it will make it nice and sticky.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
