Go to Post Our strong support is the result of 14 years of very organized "nagging". :) - OZ_341 [more]
  #16   Spotlight this post!
Unread 16-07-2016, 07:12
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Re: What sensors do your teams use
I too would like to help my team improve their use of encoders.
I'm most interested in encoders that could be used for flywheel shooters that don't require any machining to install. In 2012, I remember teams used light emitting sensors to count light and dark marks on a spinning disk.
Are these still viable?
If so, which ones work well (high reliability, easy installation, non-contacting) and are reasonably priced?
Dave
Build Mentor 2976
  #17   Spotlight this post!
Unread 16-07-2016, 07:27
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
Rookie Year: 2013
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
Dave
Build Mentor 2976
Dave,
What you're referring to is a simple IR beam break sensor (example: https://www.adafruit.com/product/2168). One of the modules is just an IR LED, and the other is a receiver that tells you if it sees the LED or not. I don't see any problem with the electronics not being reliable, but you would have to manufacture you're own spinning disk to serve as an interrupter. Those adafruit ones seem pretty straightforward to mount, but I'm sure there are some better ones out there that come in a single module.
While I think mechanically attaching a proper high speed encoder would be the right solution for a flywheel shooter, these are still pretty useful. You can use them as limit switches and even "linear encoders" with the right interrupter.
  #18   Spotlight this post!
Unread 16-07-2016, 08:26
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
If you are spinning it fast enough (quite likely), you can put the light/dark pattern directly onto the disk, and use a reflective optical sensor. If you do this, use a relatively inexpensive sensor and be ready to replace it, because it'll be located right next to that spinning wheel, and FRC robots have been known to collide with one another or the field elements. On occasion.
  #19   Spotlight this post!
Unread 16-07-2016, 08:47
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
You can also use a $10 hall effect sensor to do the same thing with a magnet. We found this pretty effective this year.
  #20   Spotlight this post!
Unread 16-07-2016, 10:46
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
If you want easy to install, I would recommend encoders that are designed to fit directly on a motor or gearbox. Vex sells a VersaPlanetary encoder, which is easy to assemble and fits right into a VersaPlanetary gearbox just like any other stage. This is what I would recommend for a shooter encoder. Andymark also now sells there PG gearmotors with encoders built in. The only assembly required is plugging in a wire. They also sell a CIMcoder now, which is designed to fit right on the shaft of a CIM. I have not used this before, so I can not speak to how well it works or how easy it is to install, but I imagine it is pretty straightforward. Andymark also sells an encoder that fits directly onto most of their gearboxes. It is kind of a pain to install and my team has broken way too many of them, but it is probably the easiest way to get an encoder on your drive train.
All of these require no machining and interface nicely with other COTS components.
  #21   Spotlight this post!
Unread 16-07-2016, 13:40
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Originally Posted by RoboChair View Post
1678 likes to use Banner laser photo eye sensors for detecting balls, other objects, and sometimes field elements.
Do you have a source for these? 469 used a ton of them as well when I was on the team, but I've found it hard to source them at a reasonable price.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #22   Spotlight this post!
Unread 20-07-2016, 15:38
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
Rookie Year: 2012
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Dave
Build Mentor 2976
For wheeled shooter speed measurement we've had good luck with this gear tooth sensor from Allegro Microsystems:
http://www.allegromicro.com/en/Produ...Cs/ATS667.aspx
As long as you can get the face of the sensor close enough to the teeth of a ferrous metal gear, you'll see one pulse per tooth that passes. They're around $7 each.
  #23   Spotlight this post!
Unread 20-07-2016, 16:12
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
While we haven't done any laser products, we've bought plenty of relatively inexpensive sensors including IR, optical, and ultrasonic rangefinders and interruption/reflection sensors at robot shop, Lynxmotion, Jameco, DigiKey, and others.
  #24   Spotlight this post!
Unread 20-07-2016, 16:13
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
I've grabbed a few off ebay a few times. Just make sure to look the exact model number and make sure it meets your specs.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
  #25   Spotlight this post!
Unread 20-07-2016, 17:09
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We use the Grayhill 63R on the drivetrain. Last year, we used the gyro on the Spartan Board--it worked great, and we likely will use it again.
Like others, we have used banner sensors/photo eyes for no-contact object tracking in the past.
We used 4 VersaPlanetary integrated encoders on our shooter wheels, scaler, and portcullis device this year. Provided you manage your ribbon cables properly and know how to match the direction of the encoder with the direction given by the SRX, I would highly recommend them.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
  #26   Spotlight this post!
Unread 21-07-2016, 17:48
ttnn58 ttnn58 is offline
FRC #4586
ttnn58 is an unknown quantity at this point
gyro&accelometer - for PID and stuff i think...
microswitch - to know if the ball is secured inside the robot
magnetic door sensor - to know if the scaling arm lifts the robots high enough for the scale to count
  #27   Spotlight this post!
Unread 22-07-2016, 21:08
David Lame David Lame is offline
FRC #0247
David Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the rough
We used the built in accelerometer of the roborio as a tilt sensor.
This year, in autonomous, we had a problem. Our robot was top heavy. If we tried to get over obstacles in autonomous, if we went too fast, we tipped. If we went too slow, we got stuck. The tilt sensor was our salvation. You can see it in action in this youtube video.
https://www.youtube.com/watch?v=roVc581joiA
As 247 goes over the moat, the announcer indicates that we look stuck. What you see on the film is that we drift back to the back side of the moat, and then suddenly charge forward.
Well, the drift isn't a drift. We programmed it to wait two seconds and check the tilt. If we weren't on flat ground, we would go slowly back, and then gun it full speed to finish the job.
It worked quite nicely. We also used it as an anti-tip sensor. If the tilt got too high, we cut wheel speed or moved in reverse to prevent tipping. That one didn't always work, as seen in the same video at about 1:10.
  #28   Spotlight this post!
Unread 03-08-2016, 20:24
SkaiCow's Avatar
SkaiCow SkaiCow is offline
AKA: William Lasater
FRC #0624 (Cryptonite)
Team Role: Leadership
Rookie Year: 2014
SkaiCow is an unknown quantity at this point
Hey I was thinking the same thing by using the gyro as an anti-tilt. Can I ask how effective that was at saving the bot from tipping? I might try it out my self next time we have a tall bot challenge.
Sent from my SAMSUNG-SM-G900A using Tapatalk
  #29   Spotlight this post!
Unread 04-08-2016, 09:04
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
Originally Posted by Steven Smith View Post
AKA, in addition to WHAT to use, do you feel there are adequate resources on HOW/WHY to use sensors, that could be addressed by linking existing content or creating new content specific to FRC?
I've seen a number of resources online of various qualities, but it would be nice to see a single published whitepaper that describes how to design a robot sensing system from top to bottom.
Challenges with such a document:
  • Keeping it up to date with changing technologies and parts availability.
  • Satisfying a large range of audiences.
I'd expect some mentors or students don't want to think about sensing system design much, and just need a quick answer as to "what should I use for situation XYZ". Others will have this design experience, and just aren't familiar with what's commonly used for FRC...
Perhaps a community-maintained wiki for this (and other topics) is an option? I haven't seen one yet, although I haven't looked very hard either...
EDIT: After a brief amount of searching, I came across https://firstwiki.github.io/wiki/tech , but it looks like there is plenty of work to be done still.
  #30   Spotlight this post!
Unread 04-08-2016, 09:31
marshall's Avatar
marshall marshall is offline
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
We use students as limit switches... the robot runs into them and they let us know about it. Decent feedback but a little slow and if they get hit too hard then they stop working sometimes. The good thing is we seem to have a never ending supply of them for replacements.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
