Go to Post We'll defintely be working on both the balancing 2 wheel robot, the 6 legged robot, and the wood chassis 8 wheel drive robot ideas this fall. - MrForbes [more]
Unread 15-07-2016, 03:53
alexboz alexboz is offline
FRC #0358 (Robotic Eagles)
Rookie Year: 2015
alexboz is an unknown quantity at this point
C++ Robot Programming in CMake/CLion
I would like to program in C++ this year, but I don't like eclipse. Last year I used IntelliJ IDEA and Java and that worked great. This year I want to use CLion which uses CMake. How would I go about setting up CMake to build and deploy code to the robot? Has anyone done something like this before?
Unread 15-07-2016, 07:43
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: C++ Robot Programming in CMake/CLion
I've not used CLion but have no doubt it will work if ...
You can tell it the name and location of the cross compiler.
You can tell it where to find the WPI library to link against.
You can tell it where to find the WPI headers to compile against.
CMake is just another rules engine. Teach it how to generate a .o file from a .c file, a .out file from a C++ file and an ELF executable file with the linker. It should work.
CLion supports gcc and gdb. Check this out ...
https://youtrack.jetbrains.com/issue/CPP-871
https://dev.widemeadows.de/2015/02/1...ap-on-windows/
Fast, cheap or working - pick any two!
Unread 06-10-2016, 05:59
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
We have been working on exactly this:
https://github.com/Team5499/frc-cpp-project-skeleton
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
