Re: [FRC Blog] Pool Noodles for the 2017 Season
I haven't seen flower noodles in local stores in any diameter. We have enough trouble finding anything between 2-1/4" and 2-3/4" in round to worry about shapes.
If I were so hyper-competitive that I wanted to give my robotics team every edge possible, I'd consider making one of each and switching bumpers based on strategy. But I don't know if I want to put in that much effort. |
Pure speculation, but I'm wondering if solid noodles on bottom and hollow noodles on top would allow a robot to have a better chance of "getting under" an opposing robot depending on that robot's bumper height and this could aid in a pushing match |
Not a good strategy at all. If you go into a season with the intention of "getting under" other robots, I can all but guarantee you will end up with at least one red card for tipping. It was bad enough as is this year with the large bumper zone and most robots were not even top heavy.
Yes solid on bottom and hollow on top and pulling the fabric as tight as possible makes your bumpers a slight wedge and is likely why this was ruled illegal. I believe 469 did this on their world champion 2014 robot. |
Regardless, you could just have two reversible bumpers. |
Somebody should probably check on Ryan to make sure he is all right. |
Yes, this is literally the subject of the thread, and the reason the discussion even started. It's been mentioned in just about every post. He literally quoted the post stating it was illegal in the post you are responding to.
#12
I believe he knew this and was just speculating on why it was made illegal.
#13
Did anyone click the "Photo Credit" link? It may contain some hints...there is a "Happy Birthday" banner, and FIRST will be 25 years old. After looking at the hints, I've reached the conclusion that next year, there will be a water game.
Or maybe not. A more reasonable prediction... Starting in 2010, there has been a game piece pattern. Spheres in the even numbered years, and other pieces in the odd numbered years: 2010 - Soccer balls 2011 - Inflatable triangle-, circle-, and square-shaped tubes 2012 - Foam basketballs 2013 - Frisbees 2014 - Exercise balls 2015 - Totes, recycling/trash cans, and noodles 2016 - Gopher SoftiBalls, AKA Boulders I predict that the game piece(s) will not be spheres. Maybe triangle shaped or a cube. There are bumpers, so there will be robot-to-robot contact. AndyMark recently released the Peanut Chasis, with a four wheel tank drive that has two omnis at one end. A kiwi drive kit was also released. I'm thinking that the field will be (mostly)flat, at least where the robots will be driving, as omnis don't like traversing rough terrain(pun intended). I also think that there will be tight spaces that robots will probably drive into and out of, making smaller chassis, easy turning, and holonomic drivetrains important. Back to the credit link, which was about a flower-themed party. Most flowers are small, so another hint that there will be tight spaces and maybe smaller robots. Unless this is just to throw us and it will be the opposite... TL;DR: Flat field, non-spherical game piece(s), tight spaces, maybe smaller robots. P.S. Congratulations Vale for beating Ryan Hall to the post! ![]() |
#14
This phenomena is widely known and has sparked a number of threads over the years. This is one of the most in depth observations: https://www.chiefdelphi.com/forums/s...+school+career
