Go to Post I think with 1114 & 217 as our partners we could have won with my refrigerator on the field. - JVN [more]
Unread 25-07-2016, 15:09
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
Rookie Year: 2012
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Drill gearboxes?
I know nowadays we like these VersaPlanetaries, but they're heavier and more expensive than the good ol' drill planetary gearboxes of yore (See: Nothing But Dewalts, =0's DeWut kit).
Anyone encountered any other good drills with gearboxes in them that can be acquired for cheap, and are reliable (all metal gears, and housing preferably)? I've heard bad things of new Harbor Freight drills (It IS horror fright...). I'd like a larger ratio, but I'm not looking for shifting (or clutch).
Nicer, easier mounting is always welcome.
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Unread 25-07-2016, 15:46
OccamzRazor's Avatar
OccamzRazor OccamzRazor is online now
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
Re: Drill gearboxes?
I don't remember the source but in 2003 we were using the Bosch drill motors that came in the KOP.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 25-07-2016, 17:15
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
The source was Bosch.
I know because I arranged the original donation, back in 1997 when those motors, gearboxes, and housings were initially provided to FIRST by my employer, Emerson Electric Co., who owned part of Skil-Bosch at the time. After Bosch took complete ownership, they also took over the donation to FIRST.
Bosch is a great sponsor that has supported FIRST for a long time.
Richard Wallace
since 2003
Unread 25-07-2016, 18:12
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Interestingly enough, I happened to see a BOSCH drill transmission on a robot with a +4000 number. Made me smile and ask where they got it. Then we had to replace the BOSCH motor with a BAG motor to make it legal. Turns out this was actually a pretty simple swap.
For the OP:
You may want to check out 12V electric screw drivers. If they are 12V, they have a higher chance of having an easy to swap in FRC motor.
I believe that BOSCH makes a nice unit that 550 motor fit into, but be careful pressing the pinion as I think they are powdered metal and easy to crack. Milwaukee has a nice unit we used on 33 for the stinger back in 2012.
Electric screw drivers are easy to use a 1/4" driver to 3/8" or 1/2" socket to adapt to more "usual" FRC sized shafts.
Unread 25-07-2016, 21:58
Thaddeus Hughes
Rookie Year: 2012
Why would voltage of the motor matter?
Funny, I actually came across a BOSCH with a 9.6v RS550 in it, stock. The ring gear is metal, first stage gears plastic. If I got two of them, I could swap the first stage plastic gears with metal ones. The overall reduction is 1:36 though, more reduction = more better for me. The immediate stuff I'm doing isn't for FRC application, but I might nudge our team towards using drill gearboxes if we can make them work...
"Yeah pretty much."
Unread 26-07-2016, 06:28
IKE's Avatar
AKA: Isaac Rife
no team (N/A)
There are some 4V screwdrivers that are very inexpensive, but the motors would be trickier to substitute.
Unread 26-07-2016, 20:08
Thaddeus Hughes
Rookie Year: 2012
Tore down a Ryobi and another drill, both of which I found at a thrift store, and they use the same 1:36 planetary and clutch combo. I'll keep you in the loop; I think I can make a smaller, lighter, cheaper, less tricky gearbox than the VPs out of these.
Also got a Harbor Freight 4.8v electric screwdriver. Tearing apart soon. Pics to come.
"Yeah pretty much."
Unread 27-07-2016, 07:59
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
If you're looking for a resource on how to implement them as well, there's a good WP here on how to use Dewalt gearboxes
https://www.chiefdelphi.com/media/papers/1592
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
