Who makes their own wheels?
In an effort to collaborate with my teaching comrades, I think a wheel project would be good. It is a great way to connect with a physics teacher with Newtons Laws of motion and overcoming the moment of inertia.
If any one has done this please offer advice. We can use our Velox CNC to mill them out of aluminum and finish on a Lathe. We can also 3d print using PLA, ABS, and Polycarbonate. Last edited by Fusion_Clint : 26-07-2016 at 00:16. |
Re: Who makes their own wheels?
We used 2.5" 3D printed idler wheels on our track system this year. They held up better than expected and were very light weight. Our test wheels didn't have bearings and the later ones used 4 skate bearings to help support the hub. Without the stacked bearings the wheels would waller out quickly. We also used some large 6" 3D printed idlers on the prototype. They used two flange bearings and held up fine.
We replaced the large printed idlers with turned aluminum. I'd recommend turning your blanks and then machining the features. I blanked the idlers at work and then had the students mill the bearing pockets. The lathe at the school is pretty tired. I uploaded the video of the process. The students had to mill the soft jaws before milling the wheel. https://www.youtube.com/watch?v=8Y0hI6mcwCg We also modified some COTS idlers, these videos may give your some idea of the secondary operations. https://www.youtube.com/watch?v=WkNYmihLryo https://www.youtube.com/watch?v=EDhaW5d9uDk If we need to ever make a lot of wheels we'd likely mill out a pattern and cast the blanks several at a time from scrap. Material cost on large wheels can add up quickly as round bar is typically a few bucks a pound. I think the large idlers were about 7 lbs each in material. We made four. A method that I'd like to try would be to mold some from castable plastic resin in a silicone mold. Any teams casting them in plastic? |
We made custom hubs for 10" Harbor Freight pneumatic wheels this year from stacked laser-cut plywood plates. Worked great and were much lighter than the original hubs. I can find a picture/ render if there's interest.
Also experimented with making CNC-routed wood wheels before the season. |
If some draft was designed in (or profiled with a tapered end mill) the wooden wheel could then be used as a pattern for casting in resin or even aluminum. |
In the years we have done West Coast drive with traction wheels we have used custom wheels. We have our sponsor machine them for us but we could make them ourselves if we so desired.
One thing you should look into is milling cutters where the shank is smaller than the cutting flutes, look up T-slot cutters. This might let you make it all in one go on your router if you are clever, it's how our sponsor machines them. The most important feature you should look at how to machine is the cross slot for installing the tread on the wheel. |
Great information RoboChair, I had not thought of T-Slots for this purpose.
We used to make custom wheels, but there are so many good options now I don't see why 99.9% of teams should. We likely won't ever again.
However, I thought my job was to educate students. Which I do year round. If my students know how to design and make a wheel, they will understand how to select the best wheel for our application. I guess we could go the route of copying what the best teams do, but I prefer my students to understand why we do things. |
#11
Also, it probabaly wasn't intentional but your tone seems to really dismiss system level design. Effective use of COTS parts is real engineering and exists in all industries. It's really an arbitrary line anyway, in terms of a robot scoring points is a wheel really all that different from a bolt? A connector? Etc...? |
#12
Since there are so many good COTS options for drivetrain wheels, another suggestion might be looking into making custom wheels out of a softer rubber to use as intake or shooter wheels.
I know 125 cast their own urethane wheels for their 2012 shooter, there should be some pics up on CD of that process. |
#13
https://www.chiefdelphi.com/forums/s...75&postcount=8 Last edited by bkahl : 27-07-2016 at 00:49. |
#14
-Brando |
#15
I like the idea of making shooter wheels. Currently on the COTS market there isn't much to be said for wheels with a large moment of inertia but remain grippy. Sure, there are the McMaster options, but those tend to be rather expensive.
Maybe something made of aluminum with holes to put steel rods into? This would also let you try balancing the wheel. |
