Go to Post ...before we ship the robot, they have to make me understand how it works. - Beth Sweet [more]
Unread 02-08-2016, 13:29
marshall's Avatar
marshall marshall is online now
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Re: What are some of your shop tips and tricks?
Originally Posted by Michael Hill View Post
I've got the second one. It is fantastic. Tom's an awesome guy. Check out his YouTube channel https://youtube.com/user/oxtoolco?
Ohh man, I forgot about the YouTube Channel! It is good!
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 02-08-2016, 23:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Originally Posted by AdamHeard View Post
This actually a pretty neat idea.
Thanks; Gixxy and I invented this process for the front panel of an 8-bit adder for his junior research project, and the team and I have continued developing ever since.
Originally Posted by GeeTwo View Post
This stuff. ..making a passable oval slot with only a drill press and hand file.
To elaborate, for an offseason drive chassis, we needed some 1/4" slots which allowed at least 1" of travel (to tension a chain run). We did this at 1.2" of travel (this technique requires a multiple of 0.4"). The attached image shows the four stages:
  1. First, do the 1/16" pilot holes every other hole for the travel length
  2. Then, remove the template and drill 1/4" holes for every other hole, including each end hole
  3. Follow up with 1/4" holes for the remaining holes (it is critical that the piece be lined up to the bit for this step, or the bit will fall out of the tiny hole into one of the large ones, or off to one side)
  4. Finally, use a flat file to knock off the scalloped edges. If you are not careful, you will wind up with a nearly rectangular hole rather than a nice slot with semicircular caps. It will still work, but won't look as nice.
Unread 01-08-2016, 17:20
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Holding a vacuum cleaner nozzle near a drill(or anything) is a great way to make cleanup easy and keep dust out of your robot, but what if you need both hands to drill and don't have someone to hold the vacuum? Just clamp the vacuum nozzle near your work area with a quick clamp. This works well on bench vises, as you can clamp the vacuum hose to the vise and direct it to the workpiece. Just don't put too much force on the clamp, it doesn't take a lot for this.
For cleaning dust off of machines/equipment/anywhere you can't get a vacuum cleaner or that won't come off with just suction, using a paintbrush in coordination with a vacuum is effective. For things you clean with air, an air compressor can also be used in coordination with a vacuum. Having a larger brush as a broom for the workbench isn't a bad idea, as you can just push the dust into piles. It gets the dust out of the way quickly, and you can pick it up later.
Have several different drill bits of the same size. Not only does this allow more people to use them and make it easier if one is misplaced, but if you're drilling something that could overheat a bit, it minimizes break times for cooling, as you can take the hot bit out, swap a cool one in, etc. This could apply to other tools as well.
Label everything clearly. Keep everything in one place.
Power strips can be good, as they provide an additional switch that can turn off equipment quickly if necessary. In a way, they prevent too many power tools in one area as they'll probably trip. If you use them, make the switch easily accessible should it be needed in an emergency.
Need to unplug something to plug something else in? Moving something somewhere else? Easy, just unplug the black power cord...wait. They're all black. Label them! It will save time and frustration.
If you have access to the breaker box for your shop and are allowed to, label all of the breakers clearly. Make sure they're readable, and not just numbers, but what is connected to their corresponding circuit breakers. Also, keep the door closed and latched, especially if you need to work around them. If the door needs to be open, find a way to hold it open all the way. Know where the door is if you're working around a breaker box.
You can do other things while a horizontal bandsaw is cutting, but keep an eye on it and make sure everyone knows that it's running.
Try to plan tasks to minimize down/wait time. If there's a wait between two tasks, such as something needs to cool down or a battery needs to charge, think about what could be done during that time. Like this:
1. Cut part
2. Drill holes
3. While drill battery is recharging and/or drill bit is cooling, deburr
4. Finish drilling...etc. You get the idea.
I think that's all I have for now.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 01-08-2016, 17:29
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Another vacuum tip: If you need to clean the PVC shavings out of a piece of PVC pipe, close off one end (your leg works great for this) and seal the other end with the shop vac. Works great
Get these. Just the first one I found. There are much cheaper ones.
Disclaimer: All references to rules and legality are from current or past seasons and it should not be assumed that any rule will remain the same in future seasons.
Unread 01-08-2016, 18:16
Team Role: Student
Rookie Year: 2016
Those look like they'd be great! I've never seen those with the built-in breakers! Or maybe I have, I just didn't notice the breaker.
