New Mill - Help with tooling
Our school recently had a Gorton Mastermil 1-22 manual milling machine donated to us by the Timken company (www.timken.com). I've attached a picture of it below.
Be relatively novice to milling we have begun watching videos on youtube about milling, etc. We are getting to the time of the year though where school supply orders need to be placed, and were hoping to hear some suggestions on tooling. What do we have to have, what should we have, what is a luxury. I know this depends on what we plan to do with it to a certain amount, but we aren't super sure even what can be done with it yet. Also if there is anyone out there familiar with this type of mill we'd like to know what ever specifics about it's tool sizes you know (we don't have it on site yet). Also how do we go about cleaning the grunge off of it? |
Re: New Mill - Help with tooling
Congrats on the "new" machine. It looks like this is the manual (PDF) for it. Also, that's a neat floor in that shop, especially if you drop something. You don't see too many like that anymore.
You'll want the following: A 6" machine vise (Kurt ang-lock type are good) Parallel set Edgefinder 6" Dial caliper some T-nuts (you may want to go for a whole generic stud, step block, and toe clamp set) Some collets - check the spindle taper, it's probably either R8 or "40-taper", but could be a #30 or even a Brown & Sharp #9 or #10, or (hopefully not) but potentially even a proprietary Gorton taper. You really need to find out which it is. HSS Endmill set (2 flute should do fine for aluminum) A set of drill bits Some taps in the common sizes you use (1/4-20, 10-32, etc) A drill chuck with shank to match your spindle taper Dial Test indicator and magnetic base Boring head with shank to match your spindle taper and a couple boring bars Fly cutter Drawbar wrench / brass hammer. That should have you pretty well covered to get started and make most things. For all of these items except the vise, Chinese is fine. All of this kind of stuff is very decent quality from China these days. I recommend Shars.com. They are discountmachine on ebay too. Little Machine Shop is another decent source. For metal surfaces, WD-40 works well for cleaning. For painted surfaces, use whatever cleaner is available, but test on a small spot to ensure it doesn't soften the paint. WD-40 with a maroon scotch brite pad can be great for removing both rust and old oil, but be very gentle with a light tough on the sliding way surfaces if they are rusted. You don't want to remove any metal whatsoever there. You can be a bit more aggressive on the table if needed. After it's all cleaned up, you'll want Mobile Vactra No. 2 way oil for all the sliding surfaces. Last edited by sanddrag : 07-30-2016 at 01:50 PM. |
Nice mill. Did you get a manual?
This page has some scans if not. http://gorton-machine.org/machines/manuals.html That mill used Brown and Sharp #9 (B & S #9) tooliong. Not as common as R-8. You'll want a fractional set of collets. A few weldon shank holders in common sizes that you use (3/8", 1/2", etc). And a drill chuck. You may start watching ebay. Sanddrag's list is fairly complete to get you started. Mobil Vactra #2 is easy to source in gallons and is a good recommendation. If you can source some Mobil Vacuoline 1409 it is better on manual machines. Mobil removed the tackifiers from Vactra #2 to improve coolant separation on cnc machines. The Vacuoline 1409 sticks to the ways like is should. I order it in 5 gallon buckets. |
Simple Green and water works well with rags. You ca use it on exposed metal but you need to be sure it dries and gets re-oiled after asap.
.WD40 and monitored doses of Evaporust have worked for me. Be aware if you leave Evaporust on carbon steel you'll eventually get loose carbon on the surface. So don't do that. It won't harm anything but it will be dang near impossible to remove the dark spots and if you use jeans or something with a pattern that pattern will be on your machine tool for a few decades. All easily avoided by getting it off the machine in 1 hour or so. Last edited by techhelpbb : 07-31-2016 at 02:54 AM. |
How many collets would we need? I'm not sure I understand why you need more than 1. Don't you take it out, change the tool and put it back? Also does anyone know of a source (other than eBay, which the school won't use) for B&S #9 collets?
As far as where to find them besides eBay, you could check Craigslist, industrial auctions, or maybe ask local machine shops if they have any. Edit: Also what Cory said. Last edited by frcguy : 07-31-2016 at 07:12 PM. |
Oops, I was thinking end mill holder/collet chuck as I have more experience with the CNC mill stuff than manual. Thanks for the clarification! |
#11
I have found a drill chuck with a straight 1/2" taper. Could I just put that in a collet for drilling?
(This B&S #9 stuff is hard to find. Can't locate a non-eBay endmill holder anywhere.) |
#12
If you are having trouble finding tooling, maybe the best bet would be to ask the company that donated the mill where they bought the tooling they used on the machine. It looks well loved/used. I bet they have a source they would be more than happy to share with you.
#13
That will work fine. My preference is a chuck with a matching end, but straight in a collet will work just fine.
#14
You probably won't need 1/16" increments. 99% of tooling for FRC is either 3/8", 1/2", 5/8", or 3/4". The only thing that I use 1/16" increment for is some dumb custom stuff that I made. In general you can get by with just 3/8", 1/2", and 3/4" as long as you buy endmills in those shank sizes. The 5/8" was just for a 5/8" endmill. Anything between 1/8" and 3/8" endmills can be found with a 3/8" shank. That being said, if you pick up a box of endmills at a machine tool auction, having all the 1/8" or even 1/16" increment sizes can come in handy. |
#15
So lets say I have a 3/8" carbide end mill. Do I just place it in the 3/8" B&S Collet and start milling?
What about a 3/8" Drill bit? Link to collet set: http://littlemachineshop.com/product...ProductID=3011 |
