Go to Post No, Dave says "that's PUMP" - dlavery [more]
Unread 01-08-2016, 13:39
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
COR Robotics and Subzero T-Shirt Cannon!
I had the awesome opportunity to work with Subzero Robotics (5690) this weekend on a T-Shirt Launching Robot. Subzero, located out of Esko, Minnesota (near Duluth) is an upcoming team in Minnesota, and incredibly fun to work with.
I CADed the robot on Creo Parametric and created a Bill of Materials which 5690 then ordered. The final robot includes multiple improvements and changes to the CAD model based on what materials were available.
Here is a short video I threw together that shows the robot in action with a few pictures as well.
Robot Specs:
- 4 cim drive with 4 toughbox micro gearboxes
- WCD using a hex output shaft from the toughbox micro
- Toughbox Micro has a gear ratio of 8.45:1
- The air tank was purchased from Walmart (believe it or not) and is designed for use on a semi truck
- The barrel has a fairly restricted range of motion from nearly vertical to about 30 degrees for safety reasons
- The system is rated for up to 125 PSI, and includes a vent plug valve set to release air at 110 PSI
- The Solenoid Valve that is used is a quick release 3/4" NPT valve
- At max pressure, the robot can launch T-shirts around 100 feet and can fire 4 times before needing to refill the air
We built the robot in 2 days with 10 people, and it was a bunch of fun! IF you have any questions or suggestions I'd love to hear them.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns 2015/2016 Project Lead: Reveal Paper
Unread 01-08-2016, 13:45
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Re: COR Robotics and Subzero T-Shirt Cannon!
I wish I had seen that tank when we built our cannon. Instead we spent a painful amount of money for this because we wanted the 1" port.
Unread 01-08-2016, 13:48
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
I wanted to go with 1" NPT, but it wasn't worth it to me for the cost.
Unread 01-08-2016, 14:03
ASD20's Avatar
AKA: Andrew
Rookie Year: 2014
And your solenoid was like $150 cheaper than ours. You really should publish your BOM because you found some good components.
Unread 01-08-2016, 14:06
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Will do! I'll be back home tonight and I'll make sure to post my BoM!
Unread 01-08-2016, 14:20
IanM IanM is offline
FRC #5690 (SubZero Robotics)
Team Role: Student
Rookie Year: 2015
IanM is an unknown quantity at this point
Thank you Ryan for all your help building this robot! It was a great learning opportunity that I'm sure will help our team in the future!
Unread 01-08-2016, 14:47
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Great job guys! How many shots per tank estimated?
"A genius is just a talented person who does his homework" T. Edison
Unread 01-08-2016, 14:50
ASD20's Avatar
AKA: Andrew
Rookie Year: 2014
Unread 02-08-2016, 12:37
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Here is the link to the Bill of Materials. It doesn't include a couple of components including the components necessary to articulate the barrel. Some additional brass fittings may also be useful for configuring the air system as desired. The logic behind not including some items is that it forces whatever team I'm working with to get creative, and engineer a solution based on the items available to them.
Thanks! When we fill the tank to 110 PSI we get around 4 solid shots. The tank drops by around 20 PSI after every shot. That would put the 4th shot at around 50 PSI which is more than enough to hit the bottom row of the stands at a high school football game!
Unread 03-08-2016, 11:02
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
For the valve here is a cheaper option that is rated for a much higher pressure. http://www.airbagit.com/Brass-Air-Va...irvalve-02.htm they also offer mounting brackets for them as well as rebuild kits. That is the one we used on a t-shirt cannon on my former team and I can verify its response time is very quick because we were able to control the distance of the shot by how long the valve opening pulse was.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 03-08-2016, 11:38
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Does a 1/2" NPT valve allow for enough air flow for a good shot? All the research I've done has told me to go no less than 3/4" NPT as the narrowest point.
Unread 03-08-2016, 11:43
Mr V's Avatar
FRC #5588 (Reign)
Team Role: Coach
Sorry I meant to post the one with the same 3/4" npt port and same 20 mm orifice as the one you used. http://www.airbagit.com/Brass-Air-Va...irvalve-06.htm
Unread 03-08-2016, 11:45
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Dang, that's a sweet find! I'm going to update my BoM to use this thing!
Unread 07-08-2016, 01:09
Team Role: Student
Rookie Year: 2015
The robot got its first real test today. We filled the barrel up with candy (with a foam plug put in first) and let it fly. The kids loved it! We haven't had any problems with the shooter so far, the only thing is that we still need to make sure it's completely air tight. I do believe we have a problem with some of our gearboxes, but hey that's what happens when you have the programmers build them. So far we are very pleased with the robot and its performance. The crowd of children and parents were very excited and impressed.
  #15   Spotlight this post!
Unread 07-08-2016, 02:01
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Looks great! That range is nothing to scoff at for sure. It could use some decorations though.
4 shots isn't much... you should think about stocking extra tanks or using a larger air tank or something.
<Now accepting CAD requests and commissions>
