Go to Post Woo for speculation! - Eugenia Gabrielov [more]
Unread 10-08-2016, 08:37
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Coach
Rookie Year: 2000
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Its twins - prototype drives
Unread 10-08-2016, 08:40
cad321 cad321 is online now
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Re: pic: Its twins - prototype drives
Are both the 4in and 6in wheels powered? If so, how are you planning to account for the differences in circumference between the two wheel sizes?
Unread 10-08-2016, 08:44
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
It looks like the 2 sets of wheels have different size sprockets, which I'm guessing is to account for this.
Unread 10-08-2016, 09:21
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
How do you plan on connecting the two sides? We had a somewhat similar design this year and we needed a lot of reinforcement to keep the chassis from flexing.
Disclaimer: All references to rules and legality are from current or past seasons and it should not be assumed that any rule will remain the same in future seasons.
Unread 10-08-2016, 09:24
346CADmen's Avatar
346CADmen 346CADmen is offline
FRC #0346
Rookie Year: 2013
346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold
Will you be sharing CAD?
Unread 10-08-2016, 09:25
GarroH GarroH is offline
AKA: Garrison Hefter
no team (None)
GarroH will become famous soon enough
Just curious, what sort of efficiency loss do you get with using the right angle gears? Is the loss in efficiency/power worth the savings in space?
FRC 2468 2011-2014
FRC 190 2015
Unread 10-08-2016, 10:47
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
Rookie Year: 2007
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
Do you have a drop center on this? Just looking at the picture it appears all wheels make contact so I would say no. Doesn't seem it would turn well.
Unread 10-08-2016, 13:12
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
Rookie Year: 2010
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
I am also interested to know this
Unread 10-08-2016, 15:03
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
Rookie Year: 2012
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
I know it's prototype but how thick are those side rails, and those are 1/2" bolts? How's the frame work here? Anything to try and stiffen things up in sideways flexure?
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Unread 10-08-2016, 15:31
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
What is the weight of one pod as configured in the picture?
It hard to tell, but it appears you only have a few degrees of chain wrap powering the outside set of 4" wheels - definitely less than 90 degrees. You'll get bad wear on that sprocket.
As others have stated, your 6" wheels are touching the ground. Turning on carpet will give you trouble.
Keep working on the prototype and let us know how it performs.
David
Unread 10-08-2016, 16:56
joeweber's Avatar
Coach team 1322
Team Role: Coach
Rookie Year: 2000
Between the bumpers and mechanisms installed this should stiffen up the frame. If I get a chance (it won't be soon) I will post the CAD drawings of the plates. We actually used the Andymark CAD to find the distances. Far as efficiency loss, I am not concerned, its small and our mechanisms are geared correctly with low power use so if we have loss at the match it will be over before it is a problem. We will just recharge the battery a little more. Between the front wheels, center and rear wheels their is a difference of .375 inch. The side plates are 3/16 thick. We do plan on cutting the bolts shorter or go with aluminum with C clips but we have had problems with the C clips coming off. The chain wrap is a problem, but we do not plan on using the center 4 inch wheels on future designs. We wanted to put double sprockets on that wheel but we only have 2 inches between the side plates and the chains barely clear now. One unit weighs 20 pounds.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 10-08-2016, 17:27
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
that's an awful lot for just one side. You're probably looking at a minumum 45-50lbs chassis once you add in the rest of it. Is there anywhere where you think you could cut down on weight? One area I would suggest is not using such a heavy plate. 2386 has run chassis similar in build from around 2010-2014. We found that as long as you supported it correctly (standoffs strategically placed throughout the "pontoon") 1/8th plate will do perfectly fine and hold up to the forces seen in a typical frc game.
Unread 10-08-2016, 17:45
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
What are they geared to? low power use isnt just gearing. its efficiency and right angle gears are less efficient than spur gears like those found in conventional drivetrains. Size also has no meaningful effect on mechanical efficiency. Also are you saying overcharging the battery is a solution to pour mechanical design? i think what people are point out is that your drivetrain will push less hard, accelerate slower and reach a lower top speed as a result of the bevel gear stage.
.375 inch wheel drop is very aggressive even for a game like this years. .125 to .188 is pretty much standard.
So are you guys planning on running 6 inch wheels 4WD or some other configuration? 4WD is generally a bad idea in FRC and is inferior to a 6 or 8 wheel drive with 4 inch wheels for numerous reasons.
What exactly are you guys trying to get out of this drivetrain that could not be done with a standard 4 or 6 cim versa drive or even a kitbot? This is a 50lb drivetrain while people have made 25-35lb drivetrains out of 2x1 tube for years now. They are simpler, cheaper, have less custom parts, are stronger, easier to assemble and maintain, have more reliability can push harder, accelerate quicker, and weigh 20-50% less than this. the only advantage I see in this is that it gets the Cims out of the way and frees up some bellypan space. if thats your sole goal then i highly recomend checking out designs for gearboxes that put the cims over the top of the drive wheels. its a simpler and more proven concept than this and has many more upsides with none of the downsides i listed in this post.
Past teams:
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 10-08-2016, 17:50
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Bevel gears are quite efficient. I'm sure that the OP is getting at least 90% efficiency out of them, unless the tolerances are way out of whack.
We used 3/8" drop due to the AM pneumatic wheels, and found that was a good number for us.For an 8WD, having a bit of extra drop doesn't hurt a lot as long as your CoG is near the center.
4WD is definitely not a good idea, agreed.
This drivetrain seems to save a ton of space compared to "normal" WCD setups, and doesn't take too many extra custom parts. They weigh less, but with a slight redesign this drivetrain too could be pretty light (maybe 40lbs for the whole deal). For this year, a 40-50lb drivetrain isn't usually a big problem because of the lightweight robots people ran in general, although the rest of the robot could be as overbuilt as this and cause you to hit 120lbs. Flipped CIM gearboxes don't save nearly as much space as this design.
<Now accepting CAD requests and commissions>
  #15   Spotlight this post!
Unread 10-08-2016, 18:34
joeweber's Avatar
Coach team 1322
Team Role: Coach
Rookie Year: 2000
If I remove the four 4 inch wheels in the center of each quarter I will still have 8 wheel drive. Far as weight this is a PROTOTYPE. We need to test it and find out how we can improve it.
