Go to Post I remember eating dinner once. Long before Build season. Now, we only eat aluminum swarf and disappointment. - BeardyMentor [more]
Unread 10-08-2016, 23:49
toodles9 toodles9 is offline
FRC #0008
toodles9 is an unknown quantity at this point
Problem with 254's library
So we are looking into using 254's library, which was released in 2015. This is the code in question: https://github.com/Team254/FRC-2015. However, we are running into issues. Deploying is successful, but there is no robot code. From the Riolog, we get the error below. Any idea what could be causing it and how to fix it? Thanks.
Exception in thread "main" java.lang.UnsatisfiedLinkError: /var/volatile/tmp/libwpilibJavaJNI1540268506574750731.so: libFRC_NetworkCommunication.so.1: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.jav a:1929)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1814)
at java.lang.Runtime.load0(Runtime.java:809)
at java.lang.System.load(System.java:1083)
at edu.wpi.first.wpilibj.hal.JNIWrapper.<clinit>(JNIW rapper.java:53)
at edu.wpi.first.wpilibj.RobotBase.initializeHardware Configuration(RobotBase.java:167)
at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:179)
