Go to Post My team does what works for my team. Let your team do the same. - Alexa Stott [more]
Unread 11-08-2016, 21:57
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
Rookie Year: 2012
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Rigorous, scientific pocketing?
Was just wondering if anyone is aware of any papers or docs on good pocketing practices that are based on either testing or FEA. "Oh that looks good" or "add more webs" aren't exactly based in any hard fact. In my own experience tweaking with FEA, simply changing the termination point of a web to a different location can allow for much lower stress distributions (and thus longer part life or lower weight).
I do have FEA packages at my personal disposal (SW and ANSYS) to verify my own designs, but I was looking for something that just gives good strategies.
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Unread 11-08-2016, 22:48
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
Re: Rigorous, scientific pocketing?
I was not able to find anything with a precursory search through CD (and I kinda assume you searched this before you started the thread, but I was curious), but I think if you look up truss design, you might find many more resources in that area. While truss bridges are NOT the same as gearbox or drivetrain plates, or whatever application for FRC, a lot of the theory behind truss patterns can be applied to pocketing patterns.
Another thing to check might be some of the softwares available for topology optimization. I haven't worked much with topology optimization, and I doubt many in FRC ever use it while designing their robots, but I imagine you could use topology optimization to design better pocketing patterns. And if you can do it in software, I'm sure you can find some guidelines or best design practices to write down.
"It's taking longer than expected, which was to be expected."
Unread 11-08-2016, 23:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
If you use Autodesk Inventor 2017, you might want to look into a rather new feature called "Shape Generator"
Unread 11-08-2016, 23:31
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
I just watched their tutorial video for this, and it looks amazing! I have used SolidThinking Inspire (a similar tool) before, but not enough to become proficient. Shape Generator looks much easier and the integration into Inventor is a definite plus. I will have to try it out when I get the chance.
For the OP, 973's RAMP has a good video on pocketing, but it might not be what you are after.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 12-08-2016, 05:45
Chris is me's Avatar
AKA: Pinecone
Honestly, build season is so quick and I'm so busy that I'd rather just over-build the mechanism a little bit and go conservative with the pocketing than do rigorous analysis to optimize the part for weight. The few extra ounces this saves is rarely worth the design time. If you have a general understanding of trusses, how your mechanism is loaded, etc. and you are conservative with your pocketing you should be okay.
It's very easy to misuse FEA tools to give you a false sense of confidence, so I would be careful with them.
Unread 12-08-2016, 09:29
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
Chris would know, he's broken more robots than many of us have built.
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
Unread 12-08-2016, 09:51
mr.roboto2826's Avatar
mr.roboto2826 mr.roboto2826 is online now
AKA: Niklas Olsen
FRC #0148 (Robowranglers)
mr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nice
It doesn't help that a few of them were made out of 99% polycarb and acrylic though.....cough cough.
First Updates Now Shows Producer.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
Unread 12-08-2016, 15:40
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Any one have a SolidWorks tutorial that shows how to use the FEA accurately for tubing and gear box loading?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 12-08-2016, 16:01
Rookie Year: 2013
http://www.solidworks.com/sw/product...y-analysis.htm
That's the page for SolidWorks' information about doing simulations on entire assemblies. Theoretically, the way to get the most accurate FEA data is to create your entire assembly (fasteners, sheet metal features, chains, belts, weldments, the whole nine yards) and then run your simulation on the whole thing. However, in my experience, that's more trouble than it's worth, especially in a 6-week timeframe. What I do these days is just take it one critical part at a time, like the main drive rails or the gearbox plates and just place constraints and loads as best I can. For that, I run lots of different simulations, including drop test, static, and cyclic simulations. For me, running 10 (maybe not actually 10, but it's a nice number) simulations on each critical component is easier and more accurate than running one giant simulation on the whole assembly, especially while I'm still designing. Granted, I'm not the most familiar with FEA yet, so take my advice with a grain of salt.
Oh, and remember that accurate FEA data and inaccurate FEA data often look very similar, and it can be difficult to get all of your constants and constraints and loads just right.
Unread 12-08-2016, 17:09
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Isogrid is used in a lot of aerospace applications.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 15-08-2016, 12:34
OccamzRazor's Avatar
OccamzRazor OccamzRazor is online now
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
As someone who teaches SOLIDWORKS FEA and does consulting work with it for a living I can say this...
Students will only have access to static FEA analysis in their student SOLIDWORKS version so you need to check the following:
-You are using a linear static material (no rubber or non-linear polymers)
Ex. HDPE is ok but PE is not because PE plastic does not have a yield strength. Any metal alloy you use commonly in FRC are covered here but you need accurate material models from the manufacturer, MATWEB.com, or somewhere reliable.
-The loads and deflections are linear. Double the load, double the deflection.
-Loads are applied slowly and gradually. No dynamic loads.
The software can do all of these things above with the correct version of SOLIDWORKS Simulation! But not with a student version!
It is also best practice to simplify. You could try to build the entire assembly in a simulation and wait 3 days for it to mesh and run to get good results or you can take it part by part and simulate that parts environment instead. The highest number of components I have ever tried to simulate simultaneously was about 600 parts. It took about 4 days to run on a $80,000 machine that most people could not fathom owning. I don't recommend that route if you are just starting out with FEA.
With that being said, I have actually started to produce content at work relating FRC, SOLIDWORKS, 3D Printing, and FEA analysis. One of the videos on FEA should be posted this week. When I have the link I will share it here.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 12-08-2016, 15:44
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Agreed.
FRC pocketing is something I heavily rely on anecdotal experience for (and occasionally remaking parts lighter or stronger in rev 2).
Even if you application of FEA is perfect, it'd be very difficult to quantify the forces involved if the part is exposed to impacts or the dynamic reactions of attached mechanisms. This pretty much just leaves small internal gearboxes that don't take much load other than their internal torques (which don't need much plate strength at all) that are easy to analyze.
I've used FEA in FRC some for A-B comparison of methods combined with anecdotal experience, but I've never determined strength required in a given plate/gusset then FEA'd to drive the pocketing to match.
