Go to Post Nonetheless, I would welcome it, as long as [The President] didn't restrict the number of discs that a Robot could hold. Oops, wait, too late, the GDC already did that. :-) - MooreteP [more]
Unread 14-08-2016, 07:33
dentistbot dentistbot is offline
dentistbot is an unknown quantity at this point
Compact, constanwas t-torque telescoping mechanism
I'm old and crufty and only work on Battlebots now, but came across this super cool lift mechanism on reddit.
https://www.youtube.com/watch?v=oIuAAN0FbO8
It consists of a flat (in z) toothed spiral section locking together flat vertical helical sections with tabs, sort of in a locked version of that thing everyone used to do by rolling up a piece of paper and then pulling the inside loop one direction and the outside loop the other direction. The highlights of this design that make it better than say, a scissor lift are:
  • Constant torque throughout travel range
  • Final z height only proportional to starting x,y dimensions, so you can build this even in a super short bot
  • Made almost entirely out of low(ish)-precision sheet metal
  • Powered descent
  • Passive holding capability
  • Hollow, for passing game elements or wires through internally
  • Isotropically stable - it's rotationally symmetric about the z-axis
I'd love to see someone prototype this during the off-season.
Unread 14-08-2016, 20:54
Forhire Forhire is offline
AKA: Randy Smith
FRC #4060 (S.W.A.G. 4060)
Rookie Year: 2015
Forhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond repute
Re: Compact, constanwas t-torque telescoping mechanism
Me too. That is a neat mechanism. This video shows the mechanism in greater detail along with an interview with the inventor.
https://www.youtube.com/watch?v=c-7b1b2R_Kg
Unread 15-08-2016, 16:08
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Very cool.
In a similar vein is the Zippermast, perhaps a simpler way of achieving the same thing:
https://youtu.be/qWcncjSCLeE
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 20-08-2016, 01:38
JCharlton's Avatar
AKA: JC
And this:
http://www.serapid.com/en/industrial...ducts/rigibelt
Serapid have other designs too. Ingenious.
Who will be the first to do this on a robot?
Unread 20-08-2016, 10:39
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Originally Posted by JCharlton View Post
And this:
I think it's already been done. I saw several teams in 2015 whose can burglars were made from IGUS cable chain (5407 and ?). I don't know how well they worked in general -the IGUS chain isn't meant to be structural
Unread 21-08-2016, 20:29
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
2451.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 22-08-2016, 04:35
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
I couldn't watch this with sound based on where I am, but can anyone relay what the basic benefits are when compared to a ball screw or lead screw?
Being correct doesn't mean you don't have to explain yourself.
Unread 22-08-2016, 05:23
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
The biggest benefit seems to be packaging. Ball screws and lead screws have to get longer and longer to lift things higher, and there would be a long screw poking above the platform being raised(annoying for purposes like theater). This new kind of lifting mechanism only have to get thicker and thicker around the base to lift things higher, and there is no rod poking above the platform. That makes for a compact unit that can expand upwards.
As for structural strength or power efficiency, I'm just a student watching some youtube videos so I wouldn't know about that.
