Go to Post This is proof we can change the world. - Al Skierkiewicz [more]
Unread 18-08-2016, 20:19
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
Rookie Year: 2014
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
Found out why the pivot on our 2014 arm wasn't working
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 18-08-2016, 20:33
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Context? Is that a VersaPlanatary stage? Either way I'm impressed
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 18-08-2016, 20:42
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Re: Found out why the pivot on our 2014 arm wasn't working
Neat! I like when things break, it's educational!
Looks like a 5:1 versaplanetary stage. What motor was driving it, where was this stage in the transmission, and what did the mechanism look like?
Unread 19-08-2016, 14:09
jnicho15's Avatar
AKA: Dan
Rookie Year: 2014
It was a 2-stage VP driven by a CIM (pre-CIM Converter). This then drove the sprocket in the middle of the picture through a chain reduction which then rotated the whole arm. We had many failures during the season with this gearbox, and in this case the output stage failed.
Unread 21-08-2016, 00:25
s_forbes's Avatar
Do you know what the reduction was for the other stage by chance?
Vexpro has a fantastic user guide for their versaplanetary gearboxes that shows what load rating you should expect the gearboxes to withstand. I bring it up every year when we're designing to show the students that there is a limit to what the gearboxes can do. It's an excellent example of "here's what the supplier says their product can handle. We have to stay in that range or it might break".
I also try to make sure that our versaplanetary assemblies have the highest reduction stages near the motor, and not the output shaft. The lower reduction stages have more meshing gears and should be able to handle higher torques, so they are the ones you want at the output of the gearbox.
By the way, I have to mention that with the beautiful carbon fiber tube and aluminum clamp construction that your team uses every year, I'm not surprised that the gearbox was the weak point. The construction of your mechanisms looks really solid!
Unread 21-08-2016, 10:01
jnicho15's Avatar
AKA: Dan
Rookie Year: 2014
Looks can be deceiving...
Unread 21-08-2016, 12:38
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
For us, this always ends up as: "Here's what the supplier has rated their product for. We've had some requirement creep, so we're going to assume they did their homework and eat into their safety factor."
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 18-08-2016, 21:14
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Nothing against your post, but I would like to make people aware of a very useful feature on imgur. Every image you upload has 7 different choices for what size to actually display via the link. You just have to add one letter to the end of the image address before the .jpg as highlighted below. On your imgur all images uploaded page, when you click on a picture there should be a window that pops up with the list of sizes below that you can select from to automatically generate the link for easy copy+paste.
Original: (what you posted) http://i.imgur.com/c4He7g5.jpg
Small Square: http://i.imgur.com/c4He7g5s.jpg
Big Square: http://i.imgur.com/c4He7g5b.jpg
Small Thumbnail: http://i.imgur.com/c4He7g5t.jpg
Medium Thumbnail: http://i.imgur.com/c4He7g5m.jpg (what I used)
Large Thumbnail: http://i.imgur.com/c4He7g5l.jpg
Huge Thumbnail: http://i.imgur.com/c4He7g5h.jpg
THIS HAS BEEN A PUBLIC SERVICE ANNOUNCEMENT.
Thank You for your time.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 18-08-2016, 21:58
frcguy's Avatar
Unregistered Unuser
Rookie Year: 2012
Additionally, when you want to share just a picture it's generally better to upload the picture to CD-Media. It has built in discussion features and makes it easier to find images as opposed to a post with an embedded image.
Unread 19-08-2016, 07:07
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
How on earth did you get that stage to fail in 4 different spots at the same time? And all across the pin holes. Almost looks like someone cut it into 4 even pieces.
Unread 19-08-2016, 10:21
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
Seeing this makes me like the VersaPlanetaries even more. Their manufacturing tolerances and material consistency must be very good for all four pin holes to fail at about the same time. This is assuming that the OP exceeded the torque ratings on the gearbox. I'd love to hear how this happened.
"It's taking longer than expected, which was to be expected."
Unread 19-08-2016, 10:25
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
It's more likely that one failed, then the rest did in order.
Unread 19-08-2016, 11:13
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
If one had failed before the others wouldn't you expect to see differences in the breaks or other damage elsewhere in the gearbox?
