Re: How are teams mounting drivetrain encoders on WCD?
We had 2 different ways of including an encoder on our drive this year. Originally with our 775pro and VP gearbox we just included the encoder stage in our VP. When we moved to a CIM/miniCIM gearbox in an effort to keep it as low profile as possible, in this case it was ~2.625in tall, we had to move the encoder away from the gearbox. We moved it to the center wheel axle.
Do other encoders generally need pull up resistors? |
It's less about the encoders, as to what is reading the encoders. The roborio has pullup resistors built in. In the cRio days the digital side card had pullup resistors built in too. Read an input on either with nothing wired up, the all will return TRUE, or that the signal is high.
449 tends to use WCP gearboxes.
If we're using a SS gearbox, we place the encoder on the gearbox output shaft, mounted under the motors. If we're using a DS gearbox, we place the encoder on a wheel shaft. The latter can be a pain if you're using chain and need adjustability (such as w/ versablocks) to maintain tension, but there are workarounds (such as slotting the mounting holes for the encoder bracket). We used to use thick surgical tubing for the coupling, but found that this actually causes a fair amount of noise in the encoder reading (my best guess is that the torsional flex in such a coupling leads to something like a stick-slip behavior, but I have no way of actually testing this). We now use helical beam couplers instead. |
The McMaster part number is 7861K44, but don't buy the 4' length unless you want it to be shipped in a 4' long cardboard tube (not coiled up in a bag). |
It'd also be a good opportunity to get the students to practice drilling into the end of a shaft accurately with our hobby lathe, which is something we seldom do (c.f. turning down a shaft). |
#11
I really like thunderhex for this, just because it has the pre-bored hole. This keeps the drill relatively concentric to the axle and helps with chip clearing (the two biggest issues you have to face with small diameter drills).
#12
We generally bore encoder holes for this reason. If your tailstock is reasonable concentric just boring with a 1/4" end mill is adequate. |
#13
The drive axle is closer in gearing to the floor than somewhere near the motor, it will have a much more accurate measurement of floor position.
#15
My mistake, I meant to say between mounting to the drive axle or a separate wheel axle.
