Re: How are teams mounting drivetrain encoders on WCD?
As for preloading, if your chains are not preloaded, as you start to drive the motors, there will be a split second where the motors will accelerate, but the wheels will stay stationary. This is because there is some slop in the gears and the chain or belt. This will then jolt the wheels when everything in the geartrain gets loaded, which can cause control issues if you want to be precise. If you preload the geartrain, which you do by moving the robot manually in the opposite direction you want to move, this jolt goes away, which allows much more controlled starts and more controlled acceleration. |
I'd assume this would mean stretching out the chain before actually putting it on finally, so that it stretches less during actual use.
Weighted wheels would be the wheels actually contacting the ground when your robot drives in the direction it's about to go. For the vast majority of 6-wheel drop centers, this will be your back wheels due to the torquing of the wheels. For 8-wheelers, it kinda depends on your specific wheel placement whether the robot is on its center sets or back sets of wheels. As for preloading this chain, they're mostly talking about removing any slack from the side of the chain that is about to be driving the robot. This prevents much shock loading from being put on your chain runs right as you start auto or teleop. And if you consider pushing the robot to be the directional opposite of the robot driving itself, pulling the robot "pre-loads" the chains so they're ready to go when you start accelerating. |
If you're going to use direct c-c, why bother using the WCP side bearing blocks? Teams have been very successful using flanged bearings directly in 0.125" and 0.100" wall tubes. The benefits of dropping the bearing blocks are lower weight, lower cost, slightly reduced tolerance-stackup and easier/more precise machining (circular holes vs rectangular cutouts). Also, what size pulleys and wheels do you plan to use? |
http://imgur.com/a/jkSMH <-- My thought behind using this bearing block was additional strength around the bearing to help mitigate the effect of load on the wheel axle. I vaguely remember seeing a thread on here awhile back showing a broken frame due to placing the bearing directly in the tube |
https://www.chiefdelphi.com/media/photos/43555 This? |
Cool, happy I could help. I just remembered it had the words "hulk" and "thumb" in the description so that's how I found it . |
