Go to Post JVN, Captain Mechanical Engineer, Mr. "Software is evil", has supported the CMU camera. I'm speechless. What's next? Copioli designing in imperial? - Karthik [more]
Unread 07-11-2002, 20:48
necroprime necroprime is offline
#0599 (Robodox)
necroprime is an unknown quantity at this point
Does anyone have an idea on how to make a joystick program for an operating board?
I'm trying to come up with a program for an operating board that uses one joystick instead of two to maneuver the robot forwards, backwards, and turning as well. However, I'm fairly new at this (I just started AP programming C++ a couple months ago)... any and all help would be greatly appreciated.
Code:
<script language="Javascript">
alert("The answer is b");
</script>
Unread 07-11-2002, 21:13
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
InnovationFIRST has a whitepaper on this.
Avalailable at:
http://www.innovationfirst.com/FIRST...ickControl.pdf
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 07-11-2002, 21:41
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
necroprime:
FYI: Your sig is a bit odd. The code tags don't actually make the code work...it does the exact opposite, in fact. It just prints out the code in a fixed font. Sorry if you wanted it that way
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 08-11-2002, 12:32
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
unfortunately for our bot, equal spike input does not make equal output at the wheels. We put the 1 joystick drive on, and the bot was uncontrollable. Keep in mind this is our test bot, which is nothing but a piece of plywood with 2 pnuematic off-road scooter tires run by 2 drill motors. It goes maybe 30-40 mph. It was funny when we put the drills in 2nd and took off, only for it to abruptly do a 360, which flung the battery off and about 30 feet away
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 08-11-2002, 12:56
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
If I recall correctly, the drill motors don't run at the same speeds, forwards and backwards. There were three in the kit, last year, two that were regular, spinning a little faster going forward, and one that was either modified or manufactured differently, which spun at the same speed as the other two did forward, in reverse. I'm not sure if this really applies to your situation (I guess I just thought it did), but I thought I'd mention it.
Again, if I recall correctly, speed controllers are called "victors", and relays are called "spikes".
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 08-11-2002, 14:38
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Thats correct.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 08-11-2002, 17:43
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
One thing for you to try after u get everything figured out is to have it so your robot can drive with 1 stick or 2. I know we had this last year, and to switch it to one stick all we did was move a switch on the operators panel. Not sure how we did it, but i thought it was pretty cool.
Purdue Alumni
Cummins, Inc.
Unread 08-11-2002, 18:35
Some code for your viewing pleasure:
if (p3_sw_aux1=1) then twoJoystick
oneJoystick:
PWM1 = (((2000 + p1_y - p1_x + 127) Min 2000 Max 2254) - 2000)
PWM2 = (((2000 + p1_y + p1_x - 127) Min 2000 Max 2254) - 2000)
goto endDrive
twoJoysticks:
PWM1=p1_y
PWM2=p2_y
endDrive:
With this code, whenever port 3 aux1 is pressed, you will drive with two joysticks, but when it isn't pressed, you only need one. Port 3 aux1 could be anything you want it to be, but most often it would be a switch of some sort on your "button box."
Unread 09-11-2002, 19:04
#0599 (Robodox)
Cool
Thanks, this really helps out... appreciate it!
Code:
</script>
Anyone looking for more program space? archiver 2001 13 24-06-2002 02:20
