Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Unread 11-08-2002, 01:12 PM
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
Analog vs Digital inputs?
The way I understand it, you can wire a switch into the digital input on the RC as a rc_sw# and then it disables a PWM or relay.
Also, I see that you can wire a sensor into a analog input as sensor#
The problem is, I can't figure out what the analog inputs output
If anyone can clarify this, i would appreciate it.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
How to access other Digital inputs on OI? DougHogg Electrical 2 03-12-2003 01:57 PM
Pre-Autonomous OI Communication Ryan Meador Programming 19 01-23-2003 08:38 PM
Competition Sequence for PBasic ttedrow Programming 12 01-23-2003 08:49 AM
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 01-20-2003 04:08 PM
Serious Controller Ideas archiver 1999 28 06-23-2002 11:01 PM
