Go to Post Coming from one of the biggest mecanum fanboys in FIRST- have fun, drive fast, and forget the haters. - Brandon Zalinsky [more]
Unread 24-08-2016, 16:37
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: High Powered Targeting light on amazon
Originally Posted by AdamHeard View Post
Which flashlight did you use?
Look above broo!
http://goo.gl/ptnOUi
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 24-08-2016, 17:12
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Too fast. Tried to sneak an edit in before someone asked. Had to dig through my purchase history.
http://team2168.org
Unread 24-08-2016, 17:44
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Rookie Year: 2011
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Pwnage, student John Duffy, designed a custom Photon Cannon back in 2013 and we redesigned it this year to make it smaller and lighter.
Here's what when into it...
CREE_XPEBWT-L1-0000-00C51 Xlamp XP-E2 High Power LED Star, Cool White = $3.49
TDK_CC6-1205SF-E Converter DC/DC 6W Sngle 12V to 5V 1.2A = $15.96
Resistors to dial in voltage and therefore brightness.
Army Surplus Len?
Custom Aluminum Housing
Powered by a spike relay
More work than a purchased flashlight, but the projection is a diamond (diode shaped) that is extremely crisp edged. John designed the aluminum housing to be slotted so we can slide the lens forward and backwards to set the focus at the nominal working distance.
Unread 24-08-2016, 19:59
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
We used this flashlight:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I chose it because it was powered by 3 AAA batteries. That is 'nominally' 4.5 volts, but I know fresh AA's sometimes go up to 1.6V. I didn't feel bad driving it from a cheapie 12 to 5 volt DC DC converter from ebay:
http://www.ebay.com/itm/Better-Water...-/380794929775
Hint: Water Game
And here's what it looked like on field:
https://www.youtube.com/watch?v=KA0_ILmJoXw
We had it focused so it spanned the bottom goal edge-to-edge.
Unread 25-08-2016, 08:49
otherguy's Avatar
sparkE
AKA: James
Originally Posted by tjwolter View Post
OK, ridiculously basic question here but bear with a mentor for a soon to be second year team. I can see how these light sources would work well in tele op, just pick up the reflective tape around your target and pull the trigger. Are they also being used significantly in autonomous?
T Wolter
They are primarily an aid in teleop to get the robot aligned at a distance quickly without added software complexity.
In auto they aren't as helpful in my opinion, unless you have a game where your robots alignment, at the beginning of auto, is critical. In this case they could be used to align your robot to some target position.
In our case, the light was helpful In debugging our auto modes in that we could see if a shot was missed due to the chassis being misaligned or if there was variability in our shooter or ball compression that led to a miss. This information, while not the primary intent of the light, was helpful in getting things dialed in.
http://team2168.org
