Go to Post Don't start celebrating yet. I haven't a clue if we can get this working. - Kevin Watson [more]
Unread 29-08-2016, 23:29
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Using a 775pro in Dusty Conditions
Since the 775pro is a fan cooled motor, is it possible to run it in very dusty conditions? For reference it would be used on a mining robot built for NASA's Robotic Mining Competition. The mining material is called regolith (not the horrible FRC kind) and it is made up of very small particles of volcanic ash called BP-1.
We are thinking about using a system of fans and filters to keep the motors cool and sealed. The logic behind using a 775pro or just a fan cooled motor in general is the weight savings vs. a cim motor for example.
So can a 775pro survive these conditions? Is this a stupid idea? Does anybody have any motor recommendations that would be better suited than the 775pro?
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns 2015/2016 Project Lead: Reveal Paper
Unread 29-08-2016, 23:35
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Using a 775pro in Dusty Conditions
Not a pro, but I have used a 775 (RS-775-18) in the same competition. Used drink cans (empty, of course, and missing one end...) around the back end of the motors and plenty of tape to seal the dust out. No motor problems, but the speed controller safeties gave us trouble... (not motor-related). This was in the drivetrain; I want to say I uploaded a photo to CD-Media some time ago of that robot. There was no cooling on the robot--remember that there is no air on the moon, so fans aren't exactly useful (FRC 2009 aside). Judges just might call ya on that.
I'm not sure I'd use a 775-Pro in that application, offhand, but if it seems to work out powerwise that might do the trick.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 29-08-2016, 23:39
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
I think it would work, but it may not last long if dust stops the fan or impedes airflow. Motors will work if they're filled with dust, but they will probably run hotter. How fine is this dust? Maybe you could put a screen or filter over the 775's vents and just clean it every run. Is there anything electrically conductive in the dust?
True. I wonder what would happen if it stalled on the moon... Also, the temperature of the moon would help make up for the lack of cooling at night. In the day, not so much...
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 29-08-2016, 23:44
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
This is really, really fine dust. As in, tyvek suit, dust mask, and safety glasses just to enter the operation area (see next to my WAI photo), and a respirator if you're in there longer than a couple minutes. I don't remember the exact size, but that's pretty fine...
Oh, and the robots get vacuumed on exiting, trying to get all of the dust off or out. I don't think there's anything conductive, but it's hard to say for sure.
Past teams:
Unread 29-08-2016, 23:53
Team Role: Student
Rookie Year: 2016
In that case, I doubt it would do well. I think I've seen motors permanently damaged from fine sheet rock dust, but I have also seen some full of household dust at a pretty fine size that continued to work. I did once accidentally send a small amount of baking soda through a vacuum cleaner motor, and it survived. Still, I probably wouldn't try it without a filter. You don't want it to fail during a competition match/run.
Unread 29-08-2016, 23:57
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
I added a link to my previous post, but I'm not sure you'll be able to see the motor shields through the frame. They'll run, but you want 'em shielded pretty well.
Past teams:
Unread 30-08-2016, 00:12
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Thanks for all the advice Eric! Good to know there is precedent for something like this. We'll obviously do some testing before implementing anything.
The 775pro is just such a powerful motor for the weight that I think it's worth the trouble to filter and cool it. Given how fine the BP-1 is, would filtration even be possible? I haven't taken the time to look into that yet.
Also, NASA allows fan cooled motors despite the fact that there is virtually no atmosphere on the Moon/Mars. This is because NASA can afford much nicer motors than us
Unread 30-08-2016, 00:26
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
If I were you I would venture into brushless land, an Inrunner is already sealed, or an outrunner doesn't really care that much, but could be sealed without too much work.
-Aren
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 30-08-2016, 00:50
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Originally Posted by Ginger Power View Post
The 775pro is just such a powerful brushed motor for the weight that I think it's worth the trouble to filter and cool it.
If your looking to reduce weight a brushless inrunner will be more powerful for the same weight and will be sealed. The resources you need such as flashing brushless ESC's with SimonK is quite well documented and is reasonably straight forward.
Is power important or is it more weight reduction that you are wanting? If you wanted to reduce weight and don't need a lot of power a small sealed motor like a BAG motor could work.
Facebook
Unread 30-08-2016, 01:30
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Out of curiosity, would the ultra-fine grit get through the bearings? How would any motor be safe for long?
<Now accepting CAD requests and commissions>
Unread 30-08-2016, 11:11
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
Let me brutally honest about this from our competition experience down at Kennedy in '13. They will not survive past the competition unless your motor enclosures are above excellent. See my link below about this.
https://www.youtube.com/watch?v=DaodHQC_MIo
We had an enclosure that was large enough to allow for some air to move around our rs775s but you will not have that in a lunar/martian environment. In testing, we wrapped our motors in several different materials but even with sand we had thermal issues because heat was being generated quickly in those wrappings. We ended up going with enclosures that had dust barriers around the drive shaft. The encoders we used were also protected with an enclosure that was a bit taller if you look in the video.
We had to replace 3-4 motors out of 6 because this material is so fine that it actually went through two military grade dust barriers and into the motor. I would recommend using CIMS if possible because if any of that dust gets in the rs motor it is done for. We even had melted fans in the motors. If we had the weight we would have went CIM motors for sure.
The challenge is a lot harder than it looks. We qualified in 6th place I think which was the first time UNCC ever qualified.
Also, do not get that stuff on your skin!!!! Clean your rover really well when you come out.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 30-08-2016, 14:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
As a point of reference, brushed motors wouldn't function on the moon at all, or would fail very quickly if they did. They can work on Mars because there's a thin atmosphere, but they cannot handle the vacuum on the moon. Outgassing of all the lubricants occurs, the brushes can be damaged (the presence of water vapor essentially lubricates the brush-commutator interface. Without it, damage rapidly occurs of graphite brushes), and the outgassing causes increased thermal load which cannot be transmitted to the surroundings well due to lack of atmosphere.
Regolith simulant is also INCREDIBLY abrasive. I would be very surprised if a 775pro held up to it for more than a few minutes here and there.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-08-2016, 15:20
kaliken kaliken is online now
294 Old Fart Mentor...
AKA: Ken S
FRC #0294 (Beach Cities Robotics)
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
Way back in 2007- 2009 when the Regolith competition was one of NASA's centennial challenges, myself and a couple other industry folks decided to enter a couple of robots in our free time. Ended up placing 2nd and 3rd.. We ended up right behind Paul back when he was at WPI doing robotics then (and now with BiteForce).
To the best of my memory, all of our drives were fully sealed, both motors and gear trains. Just like FRC we really wanted to keep our drivetrain as bullet-proof as possible. If I recall correctly we used fully sealed Maxon motors as well. I believe they were brushless as well however that part i am not remembering as well.
Plus as Cory mentioned you really are not going to have the ability for convection to cool your motor out on the lunar surface.
My thoughts that the 775pro would likely meet a relatively quick death with the amount of dust kicked up. To my knowledge, the simulant is designed if to have relatively sharp edged particles that would replicate the lunar surface and not the water eroded particles that we typically see here on earth and thus be much more abrasive than normal sand, dirt etc...
Good luck!
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
Unread 30-08-2016, 17:34
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
The competition consists of two 10 minute runs and a 10 minutes practice run. Hardly enough time to ruin a sealed motor. I'm sure most motors within our price range would have trouble in the long run, but that's one of many reasons the Mars rovers cost a lot of money
-Aren
Thanks for the recommendation Aren. I'll be sure to do my research on brushless motors before buying anything. Do you have any motors in mind?
  #15   Spotlight this post!
Unread 31-08-2016, 10:11
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
We smoked 2 of ours after the first official run but we had practiced with them for many hours prior to that. We smelled something burning and we opened up the box to find that lovely burnt plastic smell. 20 minutes between the practice and first run was all it took for the regolith to make its way into the boxes and wreck a couple of the motors.
It did plow into a boulder and go right over it though!
