Go to Post Teamwork, dedication and friendship have a lot of play in all factors of life, including a robot contest. - tenthirtythree [more]
Unread 02-09-2016, 11:35
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
adding a plane in Solidworks
Greetings Solidworks gurus.
I know zero about Solidworks, but I thought it should be a simple matter to view the cross-section created when the cylinder:
x2+y2 = 1
...is cut by the plane:
x - 2y + 3½z = 0
... in the domain:
-4<x<4 , -4<y<4 , -4<z<4
I asked a friend to do this for me, but he is struggling with it. Can you help?
Unread 02-09-2016, 11:55
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Re: adding a plane in Solidworks
Unread 02-09-2016, 11:58
Ether's Avatar
Rookie Year: 1969
Originally Posted by Ether View Post
...the plane:
x - 2y + 3½z = 0
The above equation should describe the resulting plane you'll get if you start with a plane lying in the XY plane, then rotate it 45 degrees CCW around the X axis, then rotate it 30 degrees CCW around the Y axis.
Is it easier to do it that way in Solidworks? If so, how is that done?
Unread 02-09-2016, 11:59
Ether's Avatar
Rookie Year: 1969
Originally Posted by Nate Laverdure View Post
Thanks Nate, but can you describe the steps you used to get that?
Unread 02-09-2016, 12:11
FRC #2363
Team Role: Coach
Rookie Year: 1999
1. Relabel the standard planes to minimize confusion later. Front is XY, Top is XZ, Right is YZ.
2. On the XY plane, sketch a circle with radius 1 centered at the origin.
3. Extrude this sketch along Z from the midplane to your specified extents.
4. Sketch a construction line on one of the standard planes; this will be the projection of your plane equation onto this plane. I used the XY plane. I imposed dimensions on this line (delta_x = 1, delta_y = .5) but you could make the line driven by a forumula instead if you desired.
5. Repeat the previous step on another of the standard planes. I used the XZ plane. delta_x = 1, delta_z = -1/sqrt(3).
6. Add a reference plane that is coincident to both of the construction lines drawn in the previous two steps.
7. Cut a section through the body at the reference plane.
Unread 02-09-2016, 12:15
Ether's Avatar
Rookie Year: 1969
reps to you Nate
