Go to Post wow!! Andy Baker really is a pig farmer!! and all this time i thought that paul copioli was stereotyping! - RogerR [more]
View Poll Results: What PPR (CPR * 4) do you use?
1-127 2 6.45%
128-255 3 9.68%
256-511 8 25.81%
512-1023 2 6.45%
1024-2047 7 22.58%
2048-8191 6 19.35%
8192+ 1 3.23%
None, we're too cool for encoders. 2 6.45%
Voters: 31. You may not vote on this poll
Unread 06-09-2016, 14:42
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Re: How much PPR do you use on your encoders?
Originally Posted by asid61 View Post
EDIT: On topic: The results of the poll are pretty interesting. It looks like most people are using 256 or 512 CPR encoders, with a few people using 64 CPR (or just picked the wrong option in the poll... I should have used CPR instead).
The two common encoders are 250 & 360 from US Digital. Not sure about the (much higher) others.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 06-09-2016, 13:42
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Originally Posted by Ether View Post
I think you have that backwards.
Yup.
I knew it in my head as I was typing, and it came out all weird. I edited the post to reflect the correct notation.
I had it right in the poll though.
Originally Posted by techhelpbb View Post
I
Okay then what exactly is 'cycles per revolution' in that context?
I can see a 100 cycles per revolution encoder yielding 400 pulses per revolution.
I can see a 360 cycles per revolution encoder yielding 1440 pulses per revolution.
Those are all multiples of 4.
I have taken a ton of PCB out of these encoders (they fail a lot and not just in FIRST robots but on my MaxNC CNC tools) and there is no decoding in them.
Are they just being cute and declaring the pulses you could get in the decoder circuit with a 4x decode? Effectively exchanging the meaning of PPR and CPS as other companies use it?
Probably just USDigital being weird. I find that I like their method because it essentially shows the maximum possible precision you can get with an encoder.
If your encoders fail a lot, you may want to consider just switching to magnetic encoders. 115 has killed many, many US Digital encoders in its time.
<Now accepting CAD requests and commissions>
