Go to Post Just like any good hardware or software product, "insert foot before putting mouth in gear"..... - dhitchco [more]
Unread 07-01-2002, 08:30
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
How many balls in the goals?
The remote kickoff in Novi didn't have a full complement of balls (at least not while I could get near the goal). Did anyone in New Hampshire try to fill up a goal to see how many balls would fit in it? If so, could you please post this info?
Thanks,
Chris
Unread 07-01-2002, 08:59
Unsung FIRST Hero
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Rookie Year: 1998
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: How many balls in the goals?
Thanks,
Chris
The questioned was asked during kickoff of how many balls could fit in a goal. They didn't give an exact number but said that it should be over 40 (ie it doesn't matter, all the balls fit).
Matt
Unread 07-01-2002, 09:04
Rookie Year: 1997
Re: Re: How many balls in the goals?
Matt
It matters very much for strategy. For instance, if our alliance can only control one goal, what is our maximum score possible? The maximum score depends on how many balls you can fit in one goal.
-Chris
Unread 07-01-2002, 11:10
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Like Matt said, the question was asked in NH and the answer was more then 40. There are only 20 balls on the field and a total of 10 in each alliance station.
Unless you are trying to do some type of wierd stacking, it doesn't matter if the goal can fit 50 balls or 200 balls, as there are only 40 balls on the field.
Unread 07-01-2002, 11:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
I was under the impression that there are actually 60 balls in the game.
That is, there are 10 in each player station, and an additional 20 per side of the playing field.
Am I mistaken, and there are only 10 balls per side?
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 07-01-2002, 12:13
Bill Whitley Bill Whitley is offline
Bill Whitley is an unknown quantity at this point
Send a message via AIM to Bill Whitley
There are 20 balls on each 'side' of the field. There are 0 balls on each 'end' of the field. Along with 10 in each player station, for a total of 60 balls.
-- bill
Unread 07-01-2002, 13:30
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Rookie Year: 1999
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
Right so you can only have access to 50 balls because 10 of them are in the hands of the other alliance
Unread 07-01-2002, 13:35
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Initially, you'd only have access to 50, but since the balls are 'neutral', you'd have access to the additional 10 balls when the opposing alliance decides to put them into play - if they decide to put them into play.
--Madison--
Unread 07-01-2002, 22:10
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
But if the goals are not team assigned then you can esentially gain control of all 60 balls at the end of the match, just pull all the goals with balls in it to your zone?
See... simple!
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 08-01-2002, 06:41
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
Ah, but then you're only going to get 60 points or so (10 x 2 robots).
Unread 08-01-2002, 12:24
Pterrus's Avatar
Pterrus Pterrus is offline
#0177 (The Bobcats)
Pterrus is an unknown quantity at this point
Send a message via AIM to Pterrus
See... simple!
Not so simple. The other alliance will probably not be that dumb. For all practical reasons, I can't see more than 40 balls being scored total anyway, unless some team has a ridiculously efficient harvester.
Unread 10-01-2002, 03:42
Carolyn Duncan Carolyn Duncan is offline
The_C
Carolyn Duncan is a jewel in the roughCarolyn Duncan is a jewel in the roughCarolyn Duncan is a jewel in the rough
Re: Re: Re: How many balls in the goals?
-Chris
Not if your score is 3x the score of your oposing team
C~ya,
Carolyn Danielle
Thats C like the letter not like looking through your eyes or the large bdy of water! Just the letter C and yes it's on my birth certificate!
Unread 10-01-2002, 09:04
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
May the FORCE be with you....
Ahhh....but I see nothing in the rules outlawing the use of Jedi mind tricks....so I would not rule out our controlling even those balls in the opposition player station!
(Gee...maybe I'm showing too much of our strategy....huh?)
-Quentin
Live free or die....
Unread 10-01-2002, 12:00
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
I dunno.. I think we're gonna see some ridiculous harvesters... and there will be matches where every ball is scored (maybe not all i one goal mind you)... As the strategies develop more and more people will be one upping each other simply by going for more and more balls...
imho...
JVN
Strategy Head
Clarkson University - Team 229
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Gus can put the big balls on the goals on the bridge!!! archiver 2001 0 24-06-2002 01:30
robot which can put balls on top of goals on bridge archiver 2001 4 24-06-2002 00:48
4 big balls on top of the goals archiver 2001 8 23-06-2002 22:27
goals and balls Strath General Forum 0 14-02-2002 22:34
