Go to Post Why did they get rid of the headphone jack though? =p - sportzkrazzy [more]
Unread 19-09-2016, 13:03
AlexanderSaladi AlexanderSaladi is offline
FRC #1810
AlexanderSaladi is an unknown quantity at this point
Robot Cart
All of us have to move our robot from the pits to the field and back again. From what I have seen, many teams have simplistic carts that may break or not be great for both use in the pit and transportation.
Do you believe this is an issue? Would you purchase a better cart if it was sold on AndyMark? What would you want out of this cart?
Unread 19-09-2016, 14:03
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: Robot Cart
We use a metal hydraulic cart which is definetly fine for our use. Only two problems:
  • ridiculously heave when transporting to/from an event
  • No space for tools/drive station/other things so drivers don't have to hold them
The first one isn't really an issue, but the second one definetly is.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 19-09-2016, 14:16
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
Re: Robot Cart
My team actually makes a new cart each year to fit our needs and preferences for each robot. We wouldn't buy a cart from a supplier, mostly because the people that make the cart each year enjoy it and we can make a cart that works better for our needs than a supplier could.
Our carts are usually very simple, with just a table top with a 2x4 border at around waist height. Also, we have a second level just off the ground for storage of tools and such, and one year we had drawers on the bottom level.
For 2015, our cart was a bit more complex. We built a cart out of a hydraulic car jack, so we could transport the robot with the jack lowered and raise the base of the robot to just under waist height when doing maintenance in the pit. We also included extra battery storage, a place for tools, a spot for our driver's station to mount to. It was far more complex than our usual carts, but the height of our robot in 2015 needed the adjustable cart.
"It's taking longer than expected, which was to be expected."
Unread 19-09-2016, 14:55
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Robot Cart
The problem is, there's no "one size fits all" solution to carts. Every robot is different in its length and width, wheel positions, or preferred frame support positions, which makes it really hard to create a single cart that works perfectly for every robot. Then you can add in venue restrictions (like having to fit tall robots through short doorways) and you have trouble having a cart at a working height as well. Add in transportation issues, and you have to worry about the weight of the cart and how it fits into your trailer/truck/bus.
I'm curious how we could solve all of these issues for every team - it would have to be a very creative design! I know my team has used 4 different carts over the past 10 seasons, and each one has tried to address these issues differently.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 19-09-2016, 15:07
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
Rookie Year: 2007
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
Re: Robot Cart
We use a scissor-lift style cart similar to this. We attached the top from a plastic cart we used to use (something like this) to it.
We attach wood (2X4's usually) every year to customize it to hold that years robot. Works well as an adjustable height work platform in the shop and the pit and for transport to the field. The plastic top makes a good place to temporarily put parts and tools while working on the robot. It's worked well for us for the past five years.
Unread 19-09-2016, 20:26
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: Robot Cart
We really like our cart.
It's based off one of 148's designs. It allows us to easily add blocks by screwing in 2x4s or 4x4s to the top level to lift the robot wheels off the ground in various configurations. In years where we have a very tall robot like 2015, we can pull the top deck and the front supports off and just have the lower section (that removes most of the storage but it still works).
We upgraded the handle this year with an integrated rail that holds our driver station.
Here is the full build gallery, we have CAD files if anyone wants them.
Features I like
  • Large Non-pneumatic wheels - rolls smoothly and never gets a flat
  • lip on the lower section prevents small screws and tools from rolling off
  • no lip on the top section allows us to easily sweep off metal shaving, etc
  • handle can be put on either side of the cart, not often needed but it makes it easier sometimes
  • one set of locking castors and one set of fixed wheels makes it easier to drive this cart then others I've used
  • fully removable handle so we can use the cart as a full flat bed sometimes
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 19-09-2016, 21:43
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: Robot Cart
For a simple but reliable cart, I like 330's. https://www.chiefdelphi.com/media/photos/43852 (under the tetra)--note, this is the second one of this design!
The rails slide back and forth to accommodate different robots; "stuff" goes in the mat underneath. The whole thing can be taken apart to bare frame if need be for transport (or if the handle is tripping people in the pit area again).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-09-2016, 22:03
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
Rookie Year: 2011
jimbo493 is on a distinguished road
Re: Robot Cart
Here is a pic of ours, it's not the best pic, but the frame is made out of big 80/20, and the orange rails holding the robot are adjustable up and down/removable. It's got some big heavy duty casters, so it runs smoothly, and it was a fairly easy build once we had the right 80/20 hardware, it's been great for the last 3 years, and looks pretty slick with the orange and grey powder coat.
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
Unread 20-09-2016, 10:15
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Team Role: Leadership
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: Robot Cart
Here's our robot cart. It's made of wood recycled from our 2013 crate and has supports that fit onto the underside of our frame. The supports are just screwed on, so they can be swapped out for next year. Also note the space for tools and batteries underneath it.
Unread 20-09-2016, 11:45
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Re: Robot Cart
I like carts that have an organized spot for some tool storage mainly drawers like these. Having key tools with you is a nice benefit and I've seen a few teams who've had enough drawers on their cart that most of their hands tools are always with the machine.
I'm a big fan of carts like 4564. Large tires for transporting over obstacles, a spot for the driver station, several drawers for tools, and a nice sized area for the robot. Don't forget about a spot to throw an extra battery or two.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 20-09-2016, 12:11
WesleyK's Avatar
WesleyK WesleyK is offline
O Captain! My Captain!
FRC #6060 (Circuit serpents)
Rookie Year: 2016
WesleyK is an unknown quantity at this point
Re: Robot Cart
Any cart that can hold your robot and is easy to move will work. My team had a simple two shelf cart with Robot on the top shelf and extra stuff(bumpers, batteries, etc.)on the bottom shelf.
Unread 20-09-2016, 12:44
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: Robot Cart
AndyMark used to carry two options, but I think they've been discontinued.
Hi!
