Does anyone know what the pinouts for the comp port are (Besides 6, 8 and 12)
No. Do a search. This question has been asked many times, and every time the consensus is that nobody really knows.
There are 12V and GND connections and pins for disable RC outputs and channel select enable.
If you read the manual for the OI, you will find the connections for all but the 12V connection, which is used by the Johnson "Yellow Dongle" for the "disabled" LED. Since it is inactive when the power supply is not used, the light doesn't work then. You can power the OI through this pin. Caution - pin 8 is the only pin that should be used for ground. Some printouts of the manual and the manual for the Dongle may say otherwise, but are in error. |
| Competition port cable | Ken Leung | Electrical | 2 | 17-09-2003 08:12 |
| Fried program slots? | Jeff Waegelin | Programming | 18 | 19-03-2003 18:08 |
| Dashreader.dll: A Visual Basic .NET user control to read the dashboard port | Ameya | Programming | 4 | 12-01-2003 23:40 |
| Change to Initializing Inputs and Outputs | Jferrante | Programming | 4 | 07-01-2003 11:36 |
| Relay Outputs | OddOne | Technical Discussion | 3 | 01-02-2002 19:52 |
