Go to Post .. if everybody else is buying all the thingamabobs so they can practice shoving balls into the whatsit. Maybe what you really want is to buy thingys so you can build a practice whojidingle. Being the only whojidingle robot can be a real advantage come alliance picking time ... - ChrisH [more]
Unread 20-09-2016, 19:22
Snapperbot Snapperbot is offline
FRC #4501 (Humans)
Rookie Year: 2012
Snapperbot is an unknown quantity at this point
Question Vex Motors With RoboRio
Our team has some Vex 393 motors laying around and were hoping to use them in conjunction with a couple of Motor Controller 29s to make a small "sensor bot". So far I have had no luck finding any compatible code and getting them to actually work through the PWM port on the RoboRio. Anyone have any ideas or has anyone actually got it to work?
Unread 20-09-2016, 20:16
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
Rookie Year: 2014
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Re: Vex Motors With RoboRio
The vex 29 motor controllers should work if you plug them into the roboRIO just like a talon or what ever, they all send the same signal, if it doesn't work, its probably because the power bus the RIO is sending it is to low of current/voltage. All of the PWM motor controllers use the same signal.
I found this image on google, this is how you should wire it. http://4.bp.blogspot.com/-Xzhvsr9ip2...0/modified.png
make the new Vin and Gnd wire going to the Power distro board
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 21-09-2016, 10:27
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Max voltage for the Vex 29 is 8.5 volts. Powering it from the 12 V PDB would be bad. A 5 volt source would leave it a little under powered, but should work. That is what the Crio side car powered it with. The available current on the roborio PWM pins is low, but should work for a lightly loaded motor. Any of the PWM motor controller code should work.
If you don't know what you should hook up then you should read a data sheet
