Go to Post Where's the "drill enough weight holes so we're barely under 120lbs" option? ;-) - AlecMataloni [more]
Unread 22-09-2016, 15:46
rsync rsync is offline
FRC #4913
rsync is an unknown quantity at this point
Talon SRX Breakout Board with Hall Effect Encoders
We're trying to use the Talon SRX breakout board (http://www.andymark.com/product-p/am-3281.htm) with the Talon SRX controllers and the PG71 motor. The motor comes with hall effect encoder (am-2816a) attached to the back. We connected encoder pins on the breakout board to the encoder, but are unable to read any encoder values. When printing the values in SmartDashboard, they always stay 0. We're not sure if it's a wiring issue or programming issue.
Here's some pictures for how we're connecting:
https://goo.gl/photos/6gmekW3FFhZBhXi56 (pins on breakout board)
https://goo.gl/photos/XQJWmhJqSngsGHaw5 (encoder)
Wiring question:
The breakout board has 5 pins for encoder (Ch B, V+, Ch A, IDX, V-), whereas the encoder has 4 pins (Ch B, Ch A, VCC, GND). How should those be connected?
http://files.andymark.com/Images/am-..._InfoSheet.jpg
Programming question:
We wrote a simple program with 2 CANTalon objects, and one motor following the other. We didn't yet set the PID values, hoping to just test with the encoder values. But we were not getting any values from the encoder. The code is here: https://github.com/FRC4913/Chell/blo...robot/Arm.java
(x-posted to programming)
Unread 22-09-2016, 15:58
JR0405's Avatar
JR0405 JR0405 is offline
#StaySavage
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
Rookie Year: 2011
JR0405 has a spectacular aura aboutJR0405 has a spectacular aura aboutJR0405 has a spectacular aura about
Re: Talon SRX Breakout Board with Hall Effect Encoders
I believe your wiring is wrong, you have V+ going to pin one, V- to two, A to three, and B to four when it should be B to one, V+ to pin two, A to three, skip pin 4, and V- to pin 5.
Unread 22-09-2016, 17:15
FRC #4913
This is how connected them:
Breakout Board ------- Encoder (pins from right)
Pin 1 (CH B) ------- Pin 4 (CH B)
Pin 2 (V+) ------- Pin 1 (VCC)
Pin 3 (CH A) ------- Pin 3 (CH A)
Pin 4 (Index) ------- Pin 2 (GND)
Pin 5 (V-) ------- Not connected
The pin labels on the encoder are not easy to see but here's the andymark page (http://www.andymark.com/product-p/am-2816a.htm).
We also tried leaving the Pin 2 (GND) of encoder out, but that didn't change anything.
Unread 22-09-2016, 20:32
JR0405's Avatar
#StaySavage
AKA: Jack Ross
Team Role: Driver
Rookie Year: 2011
Have you tried connecting GND to V-?
Unread 22-09-2016, 21:22
marshall's Avatar
marshall marshall is offline
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
This is not going to work. Leave the Index floating and connect GND to V-.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 22-09-2016, 23:34
FRC #4913
Thank you, that worked.
Unread 23-09-2016, 08:10
marshall's Avatar
You're welcome! Happy to help!
