Go to Post We will be stressed, we will be angry. But we need to hold ourselves to a higher standard, we need to be role models and inspirations to students. - Andrew Schreiber [more]
Unread 22-09-2016, 15:48
rsync rsync is offline
FRC #4913
rsync is an unknown quantity at this point
Talon SRX Breakout Board with Hall Effect Encoders
We're trying to use the Talon SRX breakout board (http://www.andymark.com/product-p/am-3281.htm) with the Talon SRX controllers and the PG71 motor. The motor comes with hall effect encoder (am-2816a) attached to the back. We connected encoder pins on the breakout board to the encoder, but are unable to read any encoder values. When printing the values in SmartDashboard, they always stay 0. We're not sure if it's a wiring issue or programming issue.
Here's some pictures for how we're connecting:
https://goo.gl/photos/6gmekW3FFhZBhXi56 (pins on breakout board)
https://goo.gl/photos/XQJWmhJqSngsGHaw5 (encoder)
Wiring question:
The breakout board has 5 pins for encoder (Ch B, V+, Ch A, IDX, V-), whereas the encoder has 4 pins (Ch B, Ch A, VCC, GND). How should those be connected?
http://files.andymark.com/Images/am-..._InfoSheet.jpg
Programming question:
We wrote a simple program with 2 CANTalon objects, and one motor following the other. We didn't yet set the PID values, hoping to just test with the encoder values. But we were not getting any values from the encoder. The code is here: https://github.com/FRC4913/Chell/blo...robot/Arm.java
(x-posted to electrical)
Unread 22-09-2016, 23:10
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Talon SRX Breakout Board with Hall Effect Encoders
Originally Posted by rsync View Post
Wiring question:
ChA -> ChA
ChB -> ChB
V+ -> VCC
V- -> GND
Leave the IDX (index) pin unconnected.
Is the motor the NeveRest motor from Andy Mark? If so, their pin out is:
http://files.andymark.com/LayoutPrin...+40+REV1-1.PDF
And the breakout board pin out is:
http://mach-engineering.com/products...uide_R1512.pdf
Unread 22-09-2016, 23:33
FRC #4913
Thank you, that worked.
