Go to Post Thank you NASA (except for Dave, his tormenting hints make us even) - Mike Schroeder [more]
Unread 24-09-2016, 15:09
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
pic: Piston-in-Tube Concept
Unread 24-09-2016, 15:11
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Re: pic: Piston-in-Tube Concept
Team 5830 did something similar for their climber last year, though not including the protection for the stroke (obviously, given the dimensions). It is nice how neatly these cylinders fit in such tubing.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 25-09-2016, 01:18
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Rather than using bearings, what's keeping you from using a short section of tube of the next size up, and possibly applying a thin sheet of delrin or HDPE as a bearing surface?
Some clever material selection here could eliminate the bearings entirely, while still providing the same effect.
I'd be a little leery of only using two bearing sets if straightness was critical (it often is), and would suggest 3-4 sets (2 on one side, 1-2 on the other) in such applications. Or, as noted, some clever material selection.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 25-09-2016, 12:28
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We did something like this back in 2011, but only the cylinder was in the tube, not the piston rod. Rather than using bearings we used linear slide rails on the mechanism it was actuating. Worked pretty good, and definitely saved space.
Unread 27-09-2016, 13:04
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Isn't a pneumatic cylinder on its own already a piston-in-tube device?
You could shave some weight off if you used a bracket to secure a tube to the nose of the cylinder so that only the piston rod is enclosed. You might need to rethink mounting, but the weight saved would be non-negligible. In addition, it could be argued that such a design would be more faithful to the name.
Unread 27-09-2016, 13:58
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
We did something similar with Delrin tubes and bars for our 2013 climber (underside, CAD shot). No rollers since the Delrin slides. It ended up being a good way to steamline the package for the pyramid skids. Be ready to demonstrate to the inspectors that you haven't modified the cylinders, however. Some RIs will pay close attention to any pneumatics they can't clearly see. (We showed them a spare.)
Unread 27-09-2016, 14:04
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Generally, in my experience, these kinds of things are more for saving space than weight. Square tube is also much easier to mount things to.
Unread 28-09-2016, 13:31
AKA: Alan Wells
FRC #1350 (Rambots)
Any weight that can be shaved off is more weight for future improvements. Furthermore, if you wanted to place the mount near the nose of the cylinder anyway, the method I proposed would not present any impediment.
