Go to Post You do realize that you all started jumping to conclusions without asking first which JVN he was talking about. - Jay H 237 [more]
Unread 26-09-2016, 23:02
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Kangaroo Power
I'm hesitant but ready to cut the power cable that came with our Kangaroo and tap into a 12 vdc source on the robot. The power adapter says Output 12 vdc 3 amp. During long demos and I worry at events we will forget to charge the Kangaroo at the most needed times.
Any reason why we should not do this?
Is there more going on in the power pack that came with the Kangaroo?
Unread 26-09-2016, 23:11
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
Rookie Year: 2011
jimbo493 is on a distinguished road
Re: Kangaroo Power
Most likely no, but it would probably be best to run the Kangaroo off one of the 12v 2a regulated plugs on the VRM since the battery voltage will tend to jump around off the battery. During your operation, it shouldn't draw more than 2a because I assume you won't be running any video out of it. If it does become and issue you could get a 12v reg off of amazon for fairly cheap and plug into a 10a breaker on the PDP.
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
Unread 26-09-2016, 23:30
Rookie Year: 2015
Re: Kangaroo Power
Will have to see what other HAVE done. Looked some on Amazon but have not see the a-ha device. Our VRM is well tasked currently. I'm guessing that's 2 amp for the set of 2 amp ports not 2 amps each.
The regulators I seen so far request a greater voltage to step down to 12vdc
Unread 27-09-2016, 00:51
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Rookie Year: 2013
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
Re: Kangaroo Power
If you have a second VRM, you are allowed by the rules to use multiple.
Unread 26-09-2016, 23:41
Kyle Luiten's Avatar
Kyle Luiten Kyle Luiten is offline
FRC #1595 (The Dragons)
Kyle Luiten is on a distinguished road
Re: Kangaroo Power
We power our Kangaroo from the 12V 2A supply on the VRM without any issue. During a competition, we also charge it between matches with the original power supply to avoid a low battery during a match.
I would highly recommend using Powerpole or similar connectors where you cut the cord so you can use the plug both on the robot and with the original power supply.
If you're worried about overloading the VRM 2A connections with multiple devices, you can always connect another VRM module to the PDP (although this may be more costly than a similar buck-boost device from Amazon).
Unread 26-09-2016, 23:56
Rookie Year: 2015
Re: Kangaroo Power
I was going to order just in case but
Any suggestions? I'm not quite finding the correct search words.
