Go to Post I don't mean to sound harsh, but I do not want you to get your hopes up. There are deadlines in FIRST. - RoboMom [more]
Unread 03-10-2016, 12:50
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
[FTC]: Adafruit 9-DOF Absolute Orientation IMU - BNO055
Hello.
I am looking for help with wiring this sensor to sensor controller. I must be searching google all wrong because I couldn't find help that way.
https://www.adafruit.com/products/2472
2017 FTC 11722 (Coach)
2016 FTC 10544 (Coach) Canadian Championship Finalist, Rockwell Collins Innovate Award.
2014 FRC 5064 (Mentor)
Unread 03-10-2016, 13:48
holazola holazola is offline
holazola is an unknown quantity at this point
Re: [FTC]: Adafruit 9-DOF Absolute Orientation IMU - BNO055
Is what you need here? https://learn.adafruit.com/adafruit-...ensor?view=all
Unread 03-10-2016, 15:41
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
Originally Posted by holazola View Post
Not quite. If I wanted to connect sensor to Arduino, that would be it (I may still try it though). However, not understanding enough of I2C system, I was looking for "this is what you connect stuff for FTC" guide.
Unread 03-10-2016, 13:53
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
You'll need to connect 4 wires from the Adafruit IMU to one of the Modern Robotics Device Interface Module's "I2C" Connectors:
- Power (+5V)
- Ground
- SCL (I2C Clock)
- SDA (I2C Data)
Here's a link to a tutorial on connecting the navX-Micro Robotics Navigation Sensor to the FTC system, the steps are very similar. Ignore the information about the USB interface, which is not present on the AdaFruit IMU.
Unread 03-10-2016, 14:09
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
FIRST published a great tutorial for a similar sensor here http://www.firstinspires.org/sites/d...buildguide.pdf
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 03-10-2016, 15:43
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
- Power (+5V)
- Ground
- SCL (I2C Clock)
- SDA (I2C Data)
Thank you will give it a go
I actually used it last year for that sensor, but didn't think of it to be any use for different sensor.
Thank you for quick replies.
Unread 03-10-2016, 16:23
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
The pinouts are slightly different between the two devices, however you'll still use the same interface SDA,SCL,VIN,GND to communicate via I2C. This guide is a great tutorial as to how to connect those pins into the Core Device Interface Module.
I think that a great place to start with this sensor would be the simple Arduino tutorial found here https://learn.adafruit.com/adafruit-...ensor?view=all
For more details on this sensor, check out the datasheet which will give you the I2C address specifications (Page 90) as well as commands to get data from the sensor.
Unread 03-10-2016, 16:31
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
Now, why is that when I asked question here now I can google find this thread ?
https://www.reddit.com/r/FTC/comment...sensor_wiring/
