FMS-lite / cheezy-arena - having trouble getting driver station to show up
Our team has been trying to debug a strange autonomous issue which only appeared to occur during some recent matches. In particular, at chezychamps, our autonomous would just sit there, but would work splendidly off the field (and also at the regular competitions).
To wit, I've been trying to help the team get rudimentary chezy-arena running. We've found the most helpful thread at https://www.chiefdelphi.com/forums/s...light=fms+lite - and our IP setup mirrors that discussion. We're having some trouble getting the Dlink (configured as fms-lite) to bridge - but I think we will get through that. In the meantime, I would like to ask somebody to confirm that if we choose to configure the rio as static IP (say at 10.TE.AM.9) and the driver station as static IP (10.TE.AM.6), cheezy-arena machine as static IP (10.0.100.5) and connect them all through a switch (no Dlink), we would expect to see something other than grey displayed in the match_play under the DS/R/B tabs, and be able to start a match with only 1 team (ours) once we bypass the other 5. Am I missing something here? |
Re: FMS-lite / cheezy-arena - having trouble getting driver station to show up
When using a static IP on the DS, always use 10.TE.AM.5 with a subnet mask of 255.0.0.0. The static address for the RoboRio should be 10.TE.AM.2 with a subnet mask of 255.255.255.0. The FMS (FMS Lite/Cheesy Arena) should also always be at 10.0.100.5. Here is the slightly tricky part. If you intend to use the security settings in CA, you really should be using the hardware they have called out. That said, I believe it might still be possible to use CA without it, but don't quote me on that. To flash the robot radio to use a specific SSID and WPA, you can use the Radio imaging tool from the KOP, but make sure to use it in "FMS Lite" mode. I hope this helps a bit. BTW, I wish you had asked for help at Chezy Champs, I was FTAA there. Can you provide so more detail as to what exactly your Auto routine does and how you had your components configured? (IP's etc.) |
Hello billbo911,
In terms of our autonomous routine, we had tried several different routines on the field, the simplest being the activation of four motors, which did not work. We are currently using Java command based. The link to the relevant GitHub section can be found here: https://github.com/Iron-Panthers/FRC...5fad8392ccf646 The code can also be pasted here if you would like to see it in more detail. However, I can confirm that off of the competition field, our autonomous works perfectly, and on the field it prints that it has started, but refuses to run at all. I have checked potential motor brownouts, as well as battery voltages, all to no avail. We do, in fact, have a TrendNet camera setup on 10.50.26.50, connected to our DLink, which (we thought) might have caused a bandwidth issue, but during the match, as well as during official season matches, we did not experience any bandwidth issues and our autonomous worked just fine. Our DLink was configured by the Bridging Utility at Cheesy Champs, with an IP of 10.50.26.1 Our RoboRio was configured by us (a 971 mentor also confirmed this) to 10.50.26.2 Our DS Computer was configured statically to 10.50.26.5, and we were able to connect to the robot with minimal issues. I just can't fathom something that causes just our autonomous to break on the field, and as far as I can tell, it is not a coding issue on our part (as it works off the field and at official events). Thank you for your time, -Adam N. |
Great thanks to the group for the quick replies (and, most recently, Thad) - updating Cheezy-champs fixed it on mac. Will check on PC - but no doubt that post will be helpful to others.
Got a match to work with only one robot. Good enough to make progress on trying the autonomous next. Now... there's only the remaining issue of getting the dlink to bridge to the router. A battle for another day with a different router. |
The issue is that cheesy-arena was expecting all 6 teams to be entered when the first team connects.I wish you guys had come up to us at CC and said something so we could have taken a look at this problem. Next time, please come up earlier! There was already one discrepancy at CC found between the reported match time remaining in Cheesy-arena and the FIRST FMS, FYI. It is hard to write code that conforms to a standard that isn't published... |
+1 to everything Bill said. Gateway is only useful if you have your roboRio connected to a LAN and need to point it to where it can access the internet, which you don't. |
Agreed. I was simply following all the steps described elsewhere in other threads, lest somebody bring up not configuring the GW :-)
Perhaps this is what made the Rio GUI insist on 255.0.0.0. No matter at this point, of course. Team reports that the Autonomous worked in this configuration - so crossing fingers for calgames. Again, thanks for the help. |
#10
Does your autonomous use SmartDashboard? Particularly the Sendable Chooser?
The FMS flag being set does very little to change how user code runs, but the startup/connection order and network (which is more difficult to recreate) can. |
#11
Your post was deleted because you're anonymously taking pot shots at people and not offering anything useful or constructive to the dialogue.
#12
Thank you for the helpful comments. I re-checked the settings this evening and I think the answer to my earlier question is likely 'confirmed, it should work'.
Some responses to questions asked in the thread: 1. We did indeed have Dlink related drops at the competition which looked, I think, like the 'e-stop bug'. The issues with autonomous were after this (once we replaced the flaky dlink) - thanks to the Qualcomm ref and also to Mike from 971 that helped identify that! 2. In response to billbo911 - FWIW - the Rio cannot be configured with a netmask of 255.255.255.0 if the IP is 10.TE.AM.2 and the GW is 10.0.100.1 - so I configured the netmask to 255.0.0.0, and the other settings per your post (.5 for the chezy-arena host and .5 for the DS). 3. As for the DS failure log during matches. One of our team might be able to dig this up from one of the laptops. Note, again, that the Dlink is not in play in this setup. Everything is going through a single switch (DS, Rio and Chezy-champs), pending our resolution of the bridging problem with the Dlink. So.. there is some progress this evening - I got the message on the DS saying 'begin FMS control'. However, when we click on this, the chezy-champs crashes per the below (chezy-champs running on a mac, leaving the GUI as attached): http://imgur.com/a/lffFd 2016/10/03 21:35:00 Rejecting connection from Team 5026, who is not in the current match. 2016/10/03 21:35:02 Accepting connection from Team 5026 in station B1. 2016/10/03 21:35:02 Driver station for Team 5026 connected from 10.50.26.5 panic: runtime error: invalid memory address or nil pointer dereference [signal SIGSEGV: segmentation violation code=0x1 addr=0x0 pc=0x4010f25] goroutine 11 [running]: panic(0x4620a00, 0xc42000c0d0) /usr/local/go/src/runtime/panic.go:500 +0x1a1 main.ListenForDsUdpPackets() /Users/pfairban/go/src/github.com/Team254/cheesy-arena/driver_station_connection.go:82 +0x2b5 created by main.main /Users/pfairban/go/src/github.com/Team254/cheesy-arena/main.go:25 +0x9f dhcp-157:cheesy-arena.v2016.1.0.osx xxx$ ./cheesy-arena.command goose: no migrations to run. current version: 20140823193501[/i][/i][/i] Additionally, we tried running cheesy-arena on a PC. This gave us an error of 'bind: 1160: Only one usage of each socket address is normally permitted'. This was after a fresh reboot on the PC.. so not clear what would be causing this. |
#14
As for the socket use error, does the PC you are running have FMS Lite installed on it? If so, that starts a service at bootup that uses the socket. Open up the services window, find the 2 FMS services, stop them both and set their startup type to disabled. That should fix that issue. |
#15
The RoboRio is only communicating with the DS and maybe an off board Vision processor or camera. All of which should be on the same subnet. Thus, 255.255.255.0 would be the correct subnet mask for the RoboRio. Now, the DS needs to be able to receive and respond to commands from FMS, thus the DS's subnet mask needs to be 255.0.0.0. |
