Go to Post wow Paul and Rich in a photograph, i thought that if that much nerd got together that a black hole would form - Mike Schroeder [more]
Unread 05-10-2016, 20:35
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
[FTC]: Example code of using Adafruit color sensors with multiplexer
I worked out how to use Adafruit color sensors with an i2c multiplexer. Class and example usage on github at https://github.com/Chris857/FTC-Code...s/ftc/teamcode.
To use the example, create a configuration with two "I2C Device"s, named "ada" and "mux". Edit the "ports" array to the ports on the multiplexer that you have color sensors plugged in to.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 06-10-2016, 13:22
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Re: [FTC]: Example code of using Adafruit color sensors with multiplexer
Thank you for sharing. We will definitely going to use this setup.
2017 FTC 11722 (Coach)
2016 FTC 10544 (Coach) Canadian Championship Finalist, Rockwell Collins Innovate Award.
2014 FRC 5064 (Mentor)
