pic: High Traction Drivetrain Concept
Re: pic: High Traction Drivetrain Concept
That looks great! How heavy is it, and about how much would it cost?
Weight is about 38lb without chain (I haven't decided weather this would need #35 chain or it #25 would be sufficient). I think cost would be around $1000 with the 3 CIM gearboxes (haven't done a precise calculation).
Great, now I'm thinking about lawyering the rules to use differently-sized pool noodles which make wedged bumpers...
Blue box from that rule: Quote:
You might consider looking at this post, it's for VEX but concepts apply.
Vex Forums Not to discourage you, it's great to see people looking and figuring things out for themselves, but most combinations of "what happens if I put X wheel in Y position" have been pretty thoroughly looked at for tank drivetrains. You are just left with a bunch of trade-offs, and the magic is in selecting the right drivetrain for what you need it to do, not necessarily trying to find a magic drivetrain that is far superior in all cases. In this case, let's compare to a 4 wheel omni (basically take out your center wheels), an 8 wheel omni, and an 8 wheel tank. Increasing the number of wheels is usually a factor of what you need to traverse. More wheels reduces the amount of space between the wheels, allowing it to claw over. Additionally, by staggering the drop of the wheels, such as in a 6 wheel drop center (or 8... 10... 12... whatever), you can trade off stability (rocking) for reducing turning scrub. Adding more wheels can also give you a little more "middle stability" in the neutral state. An omni wheel already has pretty good traction in the forward direction, and can push fairly well. What it doesn't have is any resistance to lateral movement. If you look at a 4 wheel omni drive (like the 2014 JVN buildBlitz, or any number of other ones), it almost drives like a drifting car. With drive practice, you can do some interesting things to throw it around... but you are also at a higher risk of being spun. So to your drivetrain, you have a risk if the omni wheels are preferentially weighted (design tolerances, weight shift under acceleration) of acting more like a 4 wheel omni drive. You probably don't have substantially more pushing power than an 8 wheel omni drive, but you have a little more resistance to being pushed sideways... while still more at risk of being spun. So basically, you have a set of tradeoffs that gives you some of the benefits of a 4 wheel omni and some of the benefits of an 8 wheel drop center tank, some of the disadvantages of either, etc. At the risk of beating this horse dead, I just want to emphasize that you don't get the advantages of both as well as dodging the disadvantages of both, it is just a blend. That being said, depending on the year, it might all be a valid set of trade-offs and lead to a pretty solid drive train. Build it and see what you think ![]() Edit: Also as a note, I'm not sure how significant the "lower bumper" comment is. Most drop drive trains (outside of pneumatic wheel years like last year) are on the order of 1/16" to 1/8". When you are talking about a several inch bumper contact patch, I think the drop center difference will be lost in the noise when compared to other variables (bumper construction, driver practice) when you talk about defensive play. (just imho) Last edited by Steven Smith : 08-10-2016 at 00:43. |
This isn't exactly new; this wasn't an uncommon layout in 2010 and later when 8WDs started gaining traction.
In short these have similar results to a 2 traction 4 omni setup vs a 6WD. Most of the problems "solved" by this drive are minuscule / imaginary. Rock shouldnt be big enough to be the difference maker in a bumper to bumper pushing match; we are literally talking about a 1/16th inch difference in bumper height here. The omni wheels lower resistance to being spun more than the 8WD all traction designs do given the same wheel layout. Omnis also don't match the lateral traction of Colsons or traded traction wheels, so you're giving up a little there. Basically, you need a really good reason to not have a drop center for this to be the right call. Given that an unequal spaced 8WD already doesn't do much rocking at all, it's hard to find a niche for this drive. |
Regarding your concern about lateral traction and being pushed or spun, I don't see how this would be any more at risk. An 8 colson wheel drivetrain with center drop will only ever have 4 colsons giving traction at any one time, just like this drivetrain. So why is this more susceptible to spins? Last edited by Osseus_Dominum : 08-10-2016 at 01:05. Reason: Quote |
Of course, maybe you shouldn't just trust my word for it. Weight up a proto-frame set up for 8WD (you can just have the 8 wheels on a frame) in one of your favorite configurations--you want 150 lb or some considerable fraction of that weight. Try to turn it by pushing it, hitting it, etc. Swap wheels and repeat. Quantitative data may be harder to get than qualitative, but you should be able to get an idea of how the robot will try to act. |
#10
Mounting your bumpers as low as possible and limited rock is an excellent way to gain traction in a pushing match, and something 558 does as well. Where we differ is that if we are designing for maximum pushing force we believe that any wheel that touches the ground should be a traction wheel. Understand that any wheel that is in contact with the ground is providing traction, and increasing the number of contact points with the ground reduces the normal force on each wheel. Typically 558 will design an 8wd with a larger center to center distance between the middle wheels to increase scrub and make the robot both more stable at speed, and more resistant to spinning.
In basic terms, an 8wd robot with drop center will provide more pushing force than an 8wd with omnis on the outside all other things equal. |
#12
By placing omni wheels in the front and rear, you are creating a drive train with what amounts to a very short wheelbase and very wide track.
This will make turning very easy, almost too easy. It may turn out to be a bit squirly to drive. You may want to consider adding a gyro to assist with driving straight. |
#13
Care to share what has lead your team to choose this over a normal 8wd with all traction wheels or shrink it down to 6wd?
Do you keep all the wheels on the same plane or do you drop the center traction wheels slightly? |
#15
When the quantity of wheels in contact with the ground is increased, the normal force on each wheel is decreased (less weight on each wheel). In the case of a 8WD with 4 "drop center" wheels, you'd have the weight of the robot on 4 wheels. 100% of the robots weight would then be placed onto those 4 traction wheels. In your corner omni 8WD, the weight of the robot is distributed among 4 traction wheels and 4 omni wheels. Assuming an even distribution of weight, you'd have 50% of the weight of the robot placed on wheels with a high coefficient of friction, and 50% of the weight of the robot placed on wheels with a low coefficient of friction. As a result, the total friction your robot generates to resist that lateral force would be less than a robot with all of its weight placed upon high traction wheels. Now, we've made quite a few assumptions to reach this point, and many things will end up being far more complicated in reality than I've presented here. For instance, resisting a spinning moment is going to be very dependent on wheel placement, drop height, and frame interactions. But I wanted to illustrate a general point. To phrase that point differently, the advantages your design has in terms of turning itself easily also serve to make it easier for other outside forces to turn. None of this is to say your design is poor, just that it will behave differently than a drop center drive. In some cases, team's have taken advantage of ultra-low resistance to turning and incorporated it into how they wanted their robot to behave. Last edited by Lil' Lavery : 09-10-2016 at 02:49. |
