pic: Hex Wrenches + Heat Shrink
Re: pic: Hex Wrenches + Heat Shrink
Sweet!
I wished I'd checked it out this past weekend at GirlPower... |
Oh man.
My team in HS used electrical tape to denote our most frequently-used sizes and it was a great system, but we had issues with the tape coming off and/or leaving an uncomfortable sticky resudie from the tape sliding around on the handle. Have you had any issues with heatshrink being pulled off or getting in the way? |
great i am going to do that to all are tools this weekend
We just spray-paint ours. While the paint comes off a little bit with use, we just repaint every other year.
I think MOE used to paint (or use nail polish or something) on a few sizes, I still see bits of it here and there, but this seemed much less messy and longer lasting. I did match the heat shrink color pattern to the remnants of paint I found. |
When I first saw this post, I thought, "Is this really post-worthy"? Then I realized it certainly was. Thanks for sharing.
We've been using heat shrink for a bit as well, it's a great trick. We've had some of it slip off, I'm looking for adhesive heat shrink in enough colors but haven't found it yet.
Our blog post with our color chart is here. http://blog.spectrum3847.org/2015/11...ion-color.html |
#11
One additional thing we did was color code the wrenches for the nuts to match those of the Allan drivers (e.g. button heads). That way when you have students screwing in a #10 button head screw with a nut on the other end, they just ask for a "red driver and a red wrench". It gets to the point that our students don't even know what size the wrench is so they just ask for colors.. great for working on your team.. bad if you need to borrow a tool from another team! Also, We have been trying to standardize on mainly button heads but for small screws we have found they strip a bit easier so we have been using socket heads for anything less than #8 |
#12
--- Back on topic: I've seen this done before. Works great as long as the tools don't get too beat up (otherwise it gets a bit tattered). If you are lucky enough to have access to a brady heat shrink printer, for bonus points, add team number and/or key size to the tubing. |
#14
Didn't color code them by week number, er, resistor code?
#15
As for the heat shrink color code, I think it's a great idea! As others have said, maybe put the size on the heat shrink too. |
